On top of the motor the actuator seal you couldnt figure that out
motherfucker, your topic is "clutch seal" and you referred to the clutch actuator as a "clutch shaft."
now how the fuck am i supposed to know you were talking about the clutch actuator? maybe i thought you were talking about the SHAFT that the clutch sits on.
and NO dumbass you dont need to split the cases for that.. you couldnt figure that out?!
well, i knew it didnt have a seal.. then again i also knew the cases didnt need to be split to install a new clutch ACTUATOR seal.
good enuff for me next time I will use correct terminology and spelling . So how do I do it
first, unhook the clutch cable from the clutch arm.
then, take out the bolt that holds the clutch arm bracket in place. its a 10mm bolt.
then pull the clutch actuator out.
use a flat blade screwdriver to pop the old seal out.
replace with new seal.
reassemble.
