robert0762 Posted March 15, 2009 Report Posted March 15, 2009 Do I have to split the cases to put in a new clutch shaft seal Quote
locogato11283 Posted March 15, 2009 Report Posted March 15, 2009 what the hell is a clutch shaft seal?? Quote
robert0762 Posted March 15, 2009 Author Report Posted March 15, 2009 On top of the motor the actuator seal you couldnt figure that out Quote
RUDEDAWG Posted March 15, 2009 Report Posted March 15, 2009 On top of the motor the actuator seal you couldnt figure that out Quote
locogato11283 Posted March 15, 2009 Report Posted March 15, 2009 On top of the motor the actuator seal you couldnt figure that out motherfucker, your topic is "clutch seal" and you referred to the clutch actuator as a "clutch shaft." now how the fuck am i supposed to know you were talking about the clutch actuator? maybe i thought you were talking about the SHAFT that the clutch sits on. and NO dumbass you dont need to split the cases for that.. you couldnt figure that out?! Quote
robert0762 Posted March 15, 2009 Author Report Posted March 15, 2009 maybe i thought you were talking about the SHAFT that the clutch sits on. Does that get a seal dumb ass Quote
locogato11283 Posted March 15, 2009 Report Posted March 15, 2009 Does that get a seal dumb ass well, i knew it didnt have a seal.. then again i also knew the cases didnt need to be split to install a new clutch ACTUATOR seal. Quote
T_Shee Posted March 15, 2009 Report Posted March 15, 2009 being more specific with your questions helps people answer your questions. hard to clerify what your calling a clutch seal is all loco is saying Quote
robert0762 Posted March 15, 2009 Author Report Posted March 15, 2009 well, i knew it didnt have a seal.. then again i also knew the cases didnt need to be split to install a new clutch ACTUATOR seal. good enuff for me next time I will use correct terminology and spelling . So how do I do it Quote
locogato11283 Posted March 15, 2009 Report Posted March 15, 2009 good enuff for me next time I will use correct terminology and spelling . So how do I do it first, unhook the clutch cable from the clutch arm. then, take out the bolt that holds the clutch arm bracket in place. its a 10mm bolt. then pull the clutch actuator out. use a flat blade screwdriver to pop the old seal out. replace with new seal. reassemble. Quote
vulvafan537240 Posted March 15, 2009 Report Posted March 15, 2009 oh my pleasure. :yelrotflmao: Quote
