Pincushion Posted March 9, 2009 Report Posted March 9, 2009 I thought I read somewhere that the bowl with the fuel passage should go on the carb with the choke plunger. Problem with that is.... both bowls have that fuel passage and they are identical as far as I can tell. Can anyone confirm that the bowls are the same and if not, what's the difference? If they are different, would having the wrong bowl on the wrong carb cause the motor not to start? Thx! Quote
black sunshine Posted March 9, 2009 Report Posted March 9, 2009 (edited) I have heard that you should keep the respective carb parts to themselves, but I forgot the reasoning. Can cause headaches :: Edited March 9, 2009 by black sunshine Quote
bode1 Posted March 9, 2009 Report Posted March 9, 2009 The one with the brass ball bearing on the front of the bowl goes on the left carb. Quote
Klaus Posted March 9, 2009 Report Posted March 9, 2009 (edited) They are not identical. The one has a jet for the choke, the other not. The one with the jet goes on the carb with the choke. http://www.bansheehq.com/forums/index.php?...;hl=float+bowls Take a flashlight and shine down each passage ( the bigger passage ), one should have a jet in it, looks similar to a pilot jet, also screws out. You should also be able to see, the one passage is completely blocked off, while the other one has a small hole on the bottom of the passage to allow fuel into it. Edited March 9, 2009 by Klaus Quote
Pincushion Posted March 9, 2009 Author Report Posted March 9, 2009 Thank you! I did use the search function, but must have used poor word choice. That's great info! Quote
Pincushion Posted March 10, 2009 Author Report Posted March 10, 2009 The one with the brass ball bearing on the front of the bowl goes on the left carb. Your advice was right on the money also. I failed to see that brass ball upon 1st, 2nd and 3rd inspection Quote
Klaus Posted March 10, 2009 Report Posted March 10, 2009 Thank you! I did use the search function, but must have used poor word choice. That's great info! No worries, hope it helped. Quote
