bry Posted March 7, 2009 Report Posted March 7, 2009 just got motor done runs good until about half throttle then cuts out no power got 195 jets in 34pj carbs any thoughts?? running 6 inch k&ns Quote
okbeast Posted March 7, 2009 Report Posted March 7, 2009 195 mains? Wow that's huge. What's your elevation? I've got 155 mains in my 34's, 421 cub. Quote
00tbanshee Posted March 7, 2009 Report Posted March 7, 2009 yeah way to big of mains.158 or 160 or so will do well. Quote
bry Posted March 7, 2009 Author Report Posted March 7, 2009 yeah way to big of mains.158 or 160 or so will do well.elev is 1250 or so in missouri near springfield the needle is up 1 clip Quote
bry Posted March 8, 2009 Author Report Posted March 8, 2009 elev is 1250 or so in missouri near springfield the needle is up 1 clipi put a set of 150s in today and it runs the same like its got a high end miss runs good til a certain rpm then cuts out +4 on timing.. this thing is killing me!! Quote
Chris-in-Cali Posted March 8, 2009 Report Posted March 8, 2009 I had issues with my mains in my 34's. The MAGIC number for me was 172 and CEL needles work wonders on 34 pj's Quote
speed-racer Posted March 8, 2009 Report Posted March 8, 2009 Start with 165 and work your way down. Look at your plug, it will tell you everything you need to know. Quote
bry Posted March 8, 2009 Author Report Posted March 8, 2009 Start with 165 and work your way down. Look at your plug, it will tell you everything you need to know.i cant get a good plug reading because i cannot use the throttle like i should if i get the bike under a pull it cuts out but it revs great sitting still.. Quote
bry Posted March 8, 2009 Author Report Posted March 8, 2009 Plug caps or coil badmight be?? the bike is an 06 i wouldnt think so though but i have seen stupider things! Quote
speed-racer Posted March 9, 2009 Report Posted March 9, 2009 Did you put new plugs in it when you dropped from that huge main jet? Quote
okbeast Posted March 9, 2009 Report Posted March 9, 2009 Also check your pick-up gap. Sounds real similar to what my buddies bike was doing. Quote
bry Posted March 9, 2009 Author Report Posted March 9, 2009 Also check your pick-up gap. Sounds real similar to what my buddies bike was doing.yse put new plugs after changing main had 6s in it put 7s in it now .. will check gap on pickup..thanks Quote
bry Posted March 9, 2009 Author Report Posted March 9, 2009 What do you mean 7's?br7es spark plugs in now but it had br6es plugs before i changed the huge main jet. Quote
