Checked tranny oil tonight for the first time since i put her back together (about 3 months ago) and oil was a grey color.....
Besides water pump impeller seal and o-ring on tube is there anything else i need to check? Ive never had clutch case off either, what else should I be aware of or look for?
Also need a name and number where i can order the seals, gasket and billet impeller while im in there.....Thanks guys
I would bet that it's the water pump seal. If the o-ring goes bad the coolant leaks on the upper case. The o-ring and clutch cover gasket would both have to go bad to get coolant in your oil.
Did you replace the clutch when you put it back together? Has it been slipping? Usually water will make it a frothy mess, kind of a coffee color. When my brother destroyed his clutch, it turned the oil a grey color. Just a thought.
mine had water bad in the oil last week i put a new o ring on the tube and it stopped the water gettin in my oil. i got an o ring from the hardware store lol. just brought my old one down there but just drain your coolant before you pull your clutch cover, and the tranny oil duh. just take the hose between motor off that lil tube and let it drain...i learned the hard way lol. not sure about impeller i know rockymountain atv would have it or anywhere probly
I think you need to stick to the street bikes
uwener - i think u need to know, if i ever ran across you id smack tha f*ck out of you!
Now that i got that out of the way, i havent replaced clutches, havent noticed any slipping either. Also where i ride theres alot of water, we can follow a shallow (1-6 inches) rock bottom creek for miles if we chose and also about the pressure washing, Is there anyway water can enter my oil? i havent noticed my coolant going down, ive been checking regularly....but thanks for the replies, i tried to research this before i posted and found the common problem areas myself tho i still cant seem to please "uwener" what a name by the way.... who always seems to have a smart ass remark everytime i post, glad i grab ur attention......lol
For starters there is only 1 e in uwenr.
Second you have just rubbed me the wrong way from day one with your post about going to your local ttrack and beating everyone. Your such a douche bag, there is alot of fast bikes on here and you post up "went to the local spot for the first time with the shee, actuallyu the first ride since i bought her they have mx track, 330 ft dirt drags and miles and miles of trails, hillclimbs etc....
well after riding some trails we headed straight for the drags, this is however where i felt at home because ive dragged streetbikes for some time....i outran everyone at the spot probally 20 different guys all on 4 bangers everyone swearing up and down i had motor work, how much money ive spent etc etc....I went with a good friend with a 03 shee.... T5's, v3s, ported and shaved head, 36mm Keihns stock gearing and wasnt impressed at all.....i beat him everytime, even let him leave first and still pulled him..... granted he did have some slick ass tires but still.... his is got to be tuned wrong or something he should kill me with the mods he has....
my mods are fmf fattys, uni filter, lid still on airbox, +4 timing, cool head 21cc domes.... -1 front sprocket.....260 mains at sea level.....
either these guys cant ride or im just that fast or just that damn good lol....... neways just wanted to share my experience! some asshole was on a 700 raptor piped getting his ass toasted in the drags then had the nerve to tell me after i won straight line dont mean shit.... i laughed and said yea it does, it means im faster! banshee ftw![/size]
Third talk about names "IEAT4STROKES" it should be DOUCHE BAG!
Edited by uwenr
Time to grow up... He asked a simple question. Either answer it.. or dont.. Its a pretty simple concept.
Alot of faster bikes here then yours too.. No need to bash on people jsut because you didn't like his story.
Never claimed my bike was fast like this db. He beats everyone.
:rolleyes: I said what I needed to say. This could go on forever.. but.. I wont clutter this guys thread worse then it already is.
Don't forget about the 2 breather tubes.
One under the rear motor mount, and one inside the water pump cover. They have rubber hoses that go to a "T", and then up behind the radiator.
i had this exact same problem last year, the oil was grey and nasty. its your water pump impeller seal. buy a new bearing because you almost always destroy them getting them out, and buy the seal, use a socket and put it on the outer race of the bearing, hammer it out, same with the seal, heat up the bearing and put the case in the freezer, drop the seal in and then the bearing.
I'd change the water pump seal 1st..Same thing happened with mine and it was the pump seal..Also with that o-ring that goes onto the piece that stick through the case off the clutch cover, even if it did leak around that it shouldnt get into the oil, the clutch cover gasket goes around that spot.
Second you have just rubbed me the wrong way from day one with your post about going to your local ttrack and beating everyone. BLA BLA BLA BLA size[/color]]
Yo, i could possibly see how you couldve took my post on that thread as being cocky, arrogant in a sense.... but come on, you seem to be leaving out ALOT on that story.... I also stated that no one out there had anything wildly modified, i said they were piped 4 pokes....seriously any DECENT running banshee piped should kill a 450 if you can ride remotely good.... there was a 250r that looked as if it seen better days, and a couple blasters... 2 overweight guys on stock motor shees. The only competition I had that day was a piped, fuel managed looney tuned 700r..... he would stay with me every race... Claimed it was fast? compared to what? my competition....yes i sure was....Against you guys on here, NEVER said that.. Its a stock stroke stock port bike.... You should be glad i was handing thier ass to them instead your spending too much time disecting my every word. I never compared my shee to ANYONES on this site not even yours, and know that my shee aint sh!t compared to most of the guys here....do i get upset? NO, i love the sport, i love to race and love to see someone with a bad ass quad even if I get my ass beat. I will not turn down a race from anyone, seat time is the best time so you can only improve....
You do need to take some advice from fouledout and grow up..... if you have nothing to share, as i stated before dont coment, if you dont like me, even better.....fucc off!
I came on here to learn and get help building my stock banshee from guys that know more about them than me....We all had to learn at some point and i shouldnt be bashed for asking questions or posting something up..... I do research before I post and that should count for something... also ive made over 100 posts from a cell phone gimme a little credit u nut hugging bastard!
