WELCOME TO THE SHEE>>>>>ZONE
Your bike looks outstanding for an old Banshee.
Wow its in great condition.
Clean her up, do all your maintenance, oil the chain, and lub up the chassis.
Check her carbs for sync and jetting.
Change the oil and have some fun.......ya got to have a maintenance baseline,before ya ride.
Go to the video section and at teh top there is a video on carb sync.
Have fun man
I have my kill switch disconnected as well.
I have a disconnect cord connected to it instead. When I dune I ride like a raped ape.
If it ever got away from me It will kill the engine at least.
Well I took the carbs off and cleaned them up and re-jetted, drained the fuel and put some fresh in, lubed up the chassis. I also found out why it would not run worth a crap, the previous owner didn't have the hose connecting the two carbs together( I guess it is the choke tube). Now it starts right up on the first or second kick :biggrin: .
I also put in a new set of plugs. Should I be running the NGK B-7 or the B-8 plugs? It had B-7's in it so that is what I got.
