well i was on my way to the beach. and when i lifted my pike up to put it in the back of my truck .. coolant came out of my left silancer.. so i put the bike back down . and looked at it .. and it looks like there was coolant coming out of my spark left spark plug... so if you guys know how i can fix this thanks ... or where to even start at...
Pull the head, and replace the head gasket. Make sure you clean the mating surfaces real good. Get all the old gasket off. Anybody can do it in 30 minutes tops.
thats what i would say.
While you have the head off I would check the cylinders for any cracks (even though it is highly unlikely) but it just takes another min or two...
ok ill check that .. because it has bigger cylinders in it .. its a 370..... well cause i baught the bike and the dude said its bored out to a 370 it has trinity stage iv head. trinity stage iv intake manifold .. 2 into1 carb.. it has the duel stator plate. and it has carbon fiber reeds . and a barnette clutch... but i also dont know what head gasket to get and size .. so if you guys can help with that thanks..
Whoa, wait a minute. I was under the impression that you had a stock head. My bad man. If you have a Trinity Stage IV head, then you need to get the o-ring kit for it. Either from Trinity, or maybe eBay. O-rings just blowing out is not as common as a stock head gasket blowing. I'd take the head completely off, have it checked for straightness and cracks, and see if an o-ring was pinched during original installation. It's also possible that you're a little lean, got too hot, and melted the red o-ring. Just a few thoughts.
BTW, there's no such thing as a dual stator plate. Maybe he meant an adjustable stator plate.
