zinger nation Posted February 28, 2009 Report Share Posted February 28, 2009 buddy took his pipe of to clean, when he pulled it off he said oil actullly poured out yup, he said poured out of the pipe. both sides did. At first i thought way rich, he is running 320 on just piped bike@ 4700FT, but im starting to wonder why his trans oil is way low. Bad seals maybe??????? the bike runs fine though. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted February 28, 2009 Report Share Posted February 28, 2009 320 mains and 4700 feet sounds too rich to me. what fuel/oil mix is he running? that could also be a problem. what mods does he have? its very unlikely that the seal is bad and tranny oil is getting into both cylinders, then into the pipes. Quote Link to comment Share on other sites More sharing options...
zinger nation Posted February 28, 2009 Author Report Share Posted February 28, 2009 320 mains and 4700 feet sounds too rich to me. what fuel/oil mix is he running? that could also be a problem. what mods does he have? its very unlikely that the seal is bad and tranny oil is getting into both cylinders, then into the pipes. thats it just pipes. and cool head 19cc. I can believe it actully ran with them jets. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted February 28, 2009 Report Share Posted February 28, 2009 it will run with a wide variety of jets. that doesnt mean its not way too rich. 320 sounds pretty big to me at that altitude. you figure out the fuel/oil mix? Quote Link to comment Share on other sites More sharing options...
zinger nation Posted February 28, 2009 Author Report Share Posted February 28, 2009 it will run with a wide variety of jets. that doesnt mean its not way too rich. 320 sounds pretty big to me at that altitude. you figure out the fuel/oil mix? ya just called him he runs it 32/1. he belray 2 stoke oil. Quote Link to comment Share on other sites More sharing options...
sheefreak Posted February 28, 2009 Report Share Posted February 28, 2009 ya just called him he runs it 32/1. he belray 2 stoke oil. If he is losing tranny fluid, I would be concerned about the crank seal. Loco is correct in that it is way too rich as well. I would bet you have a bad right side crank seal as well... Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted February 28, 2009 Report Share Posted February 28, 2009 how much tranny fluid is he losing and how did you determine it?? just curious. Quote Link to comment Share on other sites More sharing options...
dragbanshee Posted February 28, 2009 Report Share Posted February 28, 2009 If he is losing tranny fluid, I would be concerned about the crank seal. Loco is correct in that it is way too rich as well. I would bet you have a bad right side crank seal as well... Would it get in both cylinders? Quote Link to comment Share on other sites More sharing options...
zinger nation Posted February 28, 2009 Author Report Share Posted February 28, 2009 If he is losing tranny fluid, I would be concerned about the crank seal. Loco is correct in that it is way too rich as well. I would bet you have a bad right side crank seal as well... ya thats what i told him. to start im gonna jet it down to a 280, and see what that does for now. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted February 28, 2009 Report Share Posted February 28, 2009 i dont know what that oil recommends, but 32:1 is a pretty rich mixture. im runnin klotz at 50:1. at 32:1 he could be having some oil not burned off all the way, causing it to get pushed into the pipes. i would say that combined with jetting being too rich is your problem. as far as the tranny oil leaking into both cylinders and pipes, i would say thats pretty unlikely. Quote Link to comment Share on other sites More sharing options...
zinger nation Posted February 28, 2009 Author Report Share Posted February 28, 2009 i dont know what that oil recommends, but 32:1 is a pretty rich mixture. im runnin klotz at 50:1. at 32:1 he could be having some oil not burned off all the way, causing it to get pushed into the pipes. i would say that combined with jetting being too rich is your problem. as far as the tranny oil leaking into both cylinders and pipes, i would say thats pretty unlikely. I agree! thanks guys. Ill have him jet down, mix 40:1. See what happens. This orange bike( Mine) im running 300mains at @ 4700ft. its a 358 cub. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted February 28, 2009 Report Share Posted February 28, 2009 good lookin bike you got there. you ever posted it in the images section? Quote Link to comment Share on other sites More sharing options...
zinger nation Posted February 28, 2009 Author Report Share Posted February 28, 2009 good lookin bike you got there. you ever posted it in the images section? Thanks bud. No I havent, but i will. Quote Link to comment Share on other sites More sharing options...
sheefreak Posted February 28, 2009 Report Share Posted February 28, 2009 I have not seen it get into both cyls, but if it was run that way for a long time it is possible. The two are not sealed from each other, hence the reason you plug both sides when you do a leakdown test... Get your jetting figured out and go from there. I have run 32:1 w/no problems before. But I ended up running 40:1 w/klotz when I ran gas. Quote Link to comment Share on other sites More sharing options...
