banshee will start right up, idle fine, then when you give it gas it bogs down and will not accelerate. When I check both plugs they seem to be excessively wet. At first I thought it was just one cyclinder and I cleaned the pilot, but didn't help. Thought maybe broken reed, not broken, but switched the reeds in the opposite cylinder. Now, I niether cyclinder is hitting. Any one have a spark issue where it will start and idle, but when you give it gas it bogs down? Any idea witch igintion part might cause that kind of spark problem?
Are you runnin stock carbs? If so make sure the choke tube is connected between the two carbs, not the balance tube or boost bottle which ever you may have. But the 1/4 fuel line hooking both carbs together.
there is an electrical sensor attached to you e-brake that occasionally gets stuck or if your e-brake is on . Give it a wiggle and see if that works. It's all interconnected with the tors system which in most oppinions should be removed.
