BenBB Posted February 16, 2009 Report Posted February 16, 2009 Big 'ol fuel tank for sale, $75 shipped, not pretty but fully functional... Got it from NAXBansheeman like 4 or 5 years ago and paid $100 for it then, talked NYUK into some cheap nose plastic, my bars hit the tank at full lock so had Stan aka CottonEyeJoe @ Dune Devil Inc. whip me up a billet handlebar riser. This stuff all has some serious miles on it while I was racing desert, but it works perfectly with the exception of the included petcock which leaks, I always swapped my stock one back and forth from tank to tank, which is the perfect opportunity to drain the sediment out of it and inspect the plastic mesh strainers. The right side has alot more nicks in the tank than the left, not sure why it came that way when I got it. The nose plastic has a largish hole/crack and is scratched & faded to match the tank, but hey at least you don't have to hack up your own nose plastic to run the tank. Includes IMS tank, IMS cap, reaaally old leaky petcock, stock cap off an '01 with vent hose, handlebar spacer and bolts, tank rear mounting bolts, and upper mounting brackets. All the threads are intact (for the petcock mount and upper tank mount-the brass is not stripped out or loose or anything). I have bigger/closeup pictures available if you're interested, lemme know. Quote
Banshee-Predator_Owner Posted February 17, 2009 Report Posted February 17, 2009 i have on, bump for great tank, well worth $80 holds 5.5 gallons Quote
snoxrage Posted February 17, 2009 Report Posted February 17, 2009 i have on, bump for great tank, well worth $80 holds 5.5 gallons Free bump, i love mine. Quote
BenBB Posted February 17, 2009 Author Report Posted February 17, 2009 Sold, thanks alot fasstbanshee. Quote
