  • Replies 34
  • Created
  • Last Reply
Top Posters In This Topic
Noone knows why it is milky??? i am lost here
If you would slow down and explain shit better you might get a better response. Try and read your post after you type it
thanks for all the help... sorry to jack the thread... I have had this problem for a year now and got no good answer until now!! One more question... I have drained the oil/coolant out.... tipped the bike sideways and put a cinderblock under the tires to drain more...
how can I get the rest out, and how much do i have to remove before I can refill?? Can I use ATF to clean it???
As stated above just using something cheap like ATF type F, and take it for a spin. While its still warm drain the oil and refil it with new oil. Should be good to go.
I fixed it sat morning, thanks all all the imput guys.
What did the problem turn out to be?
It was my water pump seal.
