banshee_terror_ Posted February 7, 2009 Report Posted February 7, 2009 what type of medal is a 89 banshee made form. i need to get it welded and i need 1 of the tubes welded and the part were your nerf bars bolted up welded. spacificaly the part were the nut was welded on the frame for the nerfs broke off took the weld and frame with it. let me know Quote
locogato11283 Posted February 7, 2009 Report Posted February 7, 2009 what type of medal is a 89 banshee made form. i need to get it welded and i need 1 of the tubes welded and the part were your nerf bars bolted up welded. spacificaly the part were the nut was welded on the frame for the nerfs broke off took the weld and frame with it. let me know medal?? tisk tisk.. you mean meTal.. its just mild steel. weld it up with a mig or tig welder. Quote
banshee_terror_ Posted February 7, 2009 Author Report Posted February 7, 2009 (edited) yah i ment metal. im just trying to type fast so i get kind of screwy with spelling also thanks Edited February 7, 2009 by banshee_terror_ Quote
AKheathen Posted February 7, 2009 Report Posted February 7, 2009 yah i ment metal. im just trying to type fast so i get kind of screwy with spelling also thanks japaneese mild steel. a little harder, lighter, and mor brittle than regular mild steel. welds the same, but will be a little stronger if you heat it a bit first. Quote
Hilarious Posted February 7, 2009 Report Posted February 7, 2009 hmmmm....i thought these yamaha banshee frames were made from old recycled soup cans and what not. Quote
FireHead Posted February 7, 2009 Report Posted February 7, 2009 medal?? tisk tisk.. you mean meTal.. its just mild steel. weld it up with a mig or tig welder. Word. It's a Nippon spec. mild steel that is similar to 1018. :geek: Quote
BigRed350x Posted February 7, 2009 Report Posted February 7, 2009 Word. It's a Nippon spec. mild steel that is similar to 1018. :geek: Yo momma is similar to 1018. Quote
RollinRhino Posted February 7, 2009 Report Posted February 7, 2009 I have often wondered why they didn't use 4130 grade Chrome Moly like they used to on the metal framed MXers. Quote
