volcrano Posted February 5, 2009 Report Posted February 5, 2009 Yo guys.OK-i bought a 4 mil vito short rod-got it cheap so thats why i got it.Now im getting my motor ported and i heard mixed stories on the spacer plate.Some like-some dont.I talked to the guy to do the port-(i already paid him for the stock crank port before i bought the stroker-ebay)-but he said if i wanted to have it ported to the short rod he would have to have my motor.Do you have to do it that way???He said i could run blaster pistons-which i dont want to do-or run the spacer plate and the timing will be the same as a stock crank with the spacer.Im getting a cool head too so any certain dome i need i can get.Do i have to run the spacer plate-if so is it reliable or should i find someone else to do the porting-if they can do it without the motor and use different domes.I never heard of people having to send the motor too for a port,im sure it would be more accurate but i dont know what to do..All i want is a reliable ported stroked shee.Please tell me the right way to build it!!!!Thanks guys!!!! Quote
jbooker82 Posted February 5, 2009 Report Posted February 5, 2009 Sounds like you sent your cylinders to some one that really isn't familiar with the banshee. The length of the rod doesn't really have anything to do with how it is ported. Maybe he wants your whole engine so he can put the crank in and the cylinders on and use a deg wheel for the port job. I would just run regular wiseco pistons with a cut dome. Quote
sheerider1026 Posted February 5, 2009 Report Posted February 5, 2009 sounds like you should take it to someone else.. that guy doesn't know what he is talking about.. a long rod stroker crank is a ot more reliable.. i was actually looking for a 4mm crank with stock rods since i just had a fresh bore.. ditch the spacer plate and get cut domes.. i would have a builder do the engine.. sounds like you may be waisting money messing with this guy. Quote
vulvafan537240 Posted February 5, 2009 Report Posted February 5, 2009 dont use a spacer plate, get stroker domes since youre getting a cool head anyway, and get the juggs ported for the 4mill. but dont let that genius do it! use someone on here. Quote
tony cub Posted February 5, 2009 Report Posted February 5, 2009 blaster pistons on a short rod????get your shit and take it somewhere else... Quote
jbooker82 Posted February 5, 2009 Report Posted February 5, 2009 blaster pistons on a short rod????get your shit and take it somewhere else... That is what I was thinking. :shoothead: Quote
trex banshee Posted February 5, 2009 Report Posted February 5, 2009 blaster pistons on a short rod????get your shit and take it somewhere else... yeah the piston crown is going to lack a few mm's from the deck at TDC.....,.100 thousandths squish :biggrin: Quote
