Minkia38 Posted February 2, 2009 Report Posted February 2, 2009 Engine 1,000.00 Intake boots/Boost 20.00 Reeds and cages 20.00 Carbs and cable 110.00 Airbox (or air filter) 50.00 Kicker 50.00 Gas tank 25.00 Pipes OEM 25.00 Frame components Frame 300.00 Steering stem 20.00 A-arms / J-arms 300.00 Swingarm 25.00 Axle 100.00 Bearing carrier 50.00 Footpegs 10.00 Nerf Bars / Heel guards 40.00 Rear Hubs 45.00 Rear Sprocket & Hub 15.00 Rear Rotor disc & Hub 15.00 Dogbone 15.00 Rear Grab Bar 15.00 Front Bumper Pushbar 20.00 Shifter 10.00 Rear Skid Plate 20.00 Plastic Front & rear Fenders 100 - 300.00 Grill + Radiator Plastic 30.00 Gas Tank Wrap Plastic 30.00 Seat w/ latch 50.00 Fender brackets 10.00 Electrical CDI Box 50.00 Wiring harness / Loom 40.00 Coil 20.00 Headlights 70.00 on/off switch 25.00 Key w/ plastic housing 35.00 Taillight 20.00 Misc Rear brake setup 100.00 Bolt set 25.00 Rear Shock 80.00 Front shocks 80.00 Front tires & rims 100.00 Rear tires and rims 120.00 Handlebars & grips 10.00 Clutch lever / perch 10.00 Thumb Throttle lever 20.00 Radiator & Reservoir 35.00 Front brake lines 10.00 Front brake lever/rezzy 20.00 Motor Mounts 10.00 Quote
notsed Posted February 3, 2009 Report Posted February 3, 2009 what year bike is this stuff from? Electrical CDI Box 50.00 Wiring harness / Loom 40.00 Coil 20.00 Headlights 70.00 on/off switch 25.00 Key w/ plastic housing 35.00 Taillight 20.00 Quote
Minkia38 Posted February 3, 2009 Author Report Posted February 3, 2009 what year bike is this stuff from? Electrical CDI Box 50.00 Wiring harness / Loom 40.00 Coil 20.00 Headlights 70.00 on/off switch 25.00 Key w/ plastic housing 35.00 Taillight 20.00 any year you want 1987-2004 Ray Quote
Guest utleybanshee Posted February 3, 2009 Report Posted February 3, 2009 any year you want 1987-2004Ray I NEED THE BIG SQUARE TAILLIGHT AND GRAB BAR FOR AN 05 AND 06 AND A SET OF STOCK REEDS.. GOT ANY STOCK LOW BORE CYLINDERS? Quote
Minkia38 Posted February 3, 2009 Author Report Posted February 3, 2009 I NEED THE BIG SQUARE TAILLIGHT AND GRAB BAR FOR AN 05 AND 06 AND A SET OF STOCK REEDS.. GOT ANY STOCK LOW BORE CYLINDERS? sorry, i dont have any 2005 or 2006 taillights I have stock reeds for $20 low bore cylinders: $300 with pistons, bolt on condition! Quote
SandBlastin30 Posted February 7, 2009 Report Posted February 7, 2009 do you have rad. grill in dark red, i think it's on a 2004 Quote
Minkia38 Posted February 7, 2009 Author Report Posted February 7, 2009 do you have rad. grill in dark red, i think it's on a 2004 i have many red ones, but not from a 2004 rAY Quote
jasons Posted February 7, 2009 Report Posted February 7, 2009 i have many red ones, but not from a 2004rAY any pics fo the wireharness. Quote
bansheetw Posted February 12, 2009 Report Posted February 12, 2009 pics of wiring harness and swingarm???and prices??? FOR A 1998 Quote
Natemills8 Posted February 12, 2009 Report Posted February 12, 2009 What kind of rear wheels & tires you got? Quote
CAUDLE Posted February 17, 2009 Report Posted February 17, 2009 Engine 1,000.00 Intake boots/Boost 20.00 Reeds and cages 20.00 Carbs and cable 110.00 Airbox (or air filter) 50.00 Kicker 50.00 Gas tank 25.00 Pipes OEM 25.00 Frame components Frame 300.00 Steering stem 20.00 A-arms / J-arms 300.00 Swingarm 25.00 Axle 100.00 Bearing carrier 50.00 Footpegs 10.00 Nerf Bars / Heel guards 40.00 Rear Hubs 45.00 Rear Sprocket & Hub 15.00 Rear Rotor disc & Hub 15.00 Dogbone 15.00 Rear Grab Bar 15.00 Front Bumper Pushbar 20.00 Shifter 10.00 Rear Skid Plate 20.00 Plastic Front & rear Fenders 100 - 300.00 Grill + Radiator Plastic 30.00 Gas Tank Wrap Plastic 30.00 Seat w/ latch 50.00 Fender brackets 10.00 Electrical CDI Box 50.00 Wiring harness / Loom 40.00 Coil 20.00 Headlights 70.00 on/off switch 25.00 Key w/ plastic housing 35.00 Taillight 20.00 Misc Rear brake setup 100.00 Bolt set 25.00 Rear Shock 80.00 Front shocks 80.00 Front tires & rims 100.00 Rear tires and rims 120.00 Handlebars & grips 10.00 Clutch lever / perch 10.00 Thumb Throttle lever 20.00 Radiator & Reservoir 35.00 Front brake lines 10.00 Front brake lever/rezzy 20.00 Motor Mounts 10.00 can you send me a pick of the nerf bars and the shocks please!! [email protected] Quote
wvelectrician Posted February 17, 2009 Report Posted February 17, 2009 could u ook me up with some pics of the motor Quote
yammyboy3 Posted February 17, 2009 Report Posted February 17, 2009 how much for an a arm frame titled and what colors do you ahve Quote
Minkia38 Posted February 17, 2009 Author Report Posted February 17, 2009 please send all picture requests to me at [email protected] Frames, a-arm style, I have silver and black. J-arm style I have silver and red what color shocks do you want? I have red, yellow, white.... please see my signature for all my items to purchase immediately Quote
