what size carbs should i be running for rz 350 juggs on my banshee and how do i tell what size is on it is it marked bought banshee with rz juggs on it.
not sure what size you should run but to check what size that are on it you have to take a set of mics and check the inside if the filter side of the carb.but make sure you check back close to where the slide comes down
soory but dont understand iam from moncton new bruniswick canada one one knowns about banshee with rz swap,i bought it like this.
