gerry
Everything posted by gerry
  1. what set do you have to run the servo motor,do i have to get cables made,what the easyer and cheaper,can i run banshee harness w
  2. hey man ,i have rz top end on my 2001 banshee but servo motor is not hook up where and what do i need to run power valves,could u tell me how u did it ,did u use the banshee harness cause that what i have and it runs but powervalves are not hooked up thanks
  3. yes i had to dent left side where the powervalve is for the pipe to be close to the frame
  4. i thought vforce3s are for drag i read up on here,i have rz top end
  5. whats the best reed valves for the stock reed cages
  6. How to know if there sync the same,how to sync carbs ur self
  7. i have a o1 banshee with rz juggs but powervalve are not hooked up,i have pro circuit pipes front to back with kn filter with 300 main jet.i bought it two yrs ago and end of last summer left cylinder was back firering and head pipe was hot,so i took compression test 60 psi in left ,100 in right,.it still runs but i want to rebuild anyone have suggeastion want i should be looking for when i tear apart engine,teared boot ,crank bearings seals ecy. o yeah and my spark plug was grey like.
  8. soory but dont understand iam from moncton new bruniswick canada one one knowns about banshee with rz swap,i bought it like this.
  9. what size carbs should i be running for rz 350 juggs on my banshee and how do i tell what size is on it is it marked bought banshee with rz juggs on it.
  10. i not sure if bad where can u get new packing does it have to be from pro circuit thanks
  11. i have a question for u guys is it bad to take out packing out of silencers,i have pro circuit on my banshee and i took the packing out for more sound is it going to hurt the engine,thanks
  12. what is his email,does this guy do the swap and knows lots
  13. so where should i look for on ebay for parts i need to make ypvs werk.the bike runs with the jugs on it work good but would work better with powervalve hooked up so i read,does anyone have pics of step of there swap with stock wiring would help me more,but thanks guys for replys cause in moncton new bruniswick no one knows about this swap,the buddy i bought from bought it swap already and he didnt know much.later
  14. do u have pics of urs done
  15. i have the jugs they have ypvs and buddy said i have the rz coil,but not sure i bought a year a go and thats what he said now iam going to rebuild,so where can and what do i need to hook up the powervalves.thanks
  16. thanks but i like to see pics from someones bike,close ups where to mount servo and battery to a stock banshee wirering .
  17. yes im looking for ideas how hook upand what parts are needed to make the ypvs cylinders work on the banshee,i have 01 with the ypvs cylinders.i bought it like that and im only running the cylinders,so it is like a stock banshee it still fast but i want toknow how to rig up to make powervalves work so i will have the power it is suppost to have anyone help me thanks.
  18. yes it already run i bought it like that but the powervalves r not hooked up,i have the ypvs cylinders and i had to weld flages on my procircuit head pipes but now im going to rebuild cause i have 50psi in right cylinder and 100psi in right still runs but going to rebuild top to bottom and then want to make powervalve system work properly,so ill need to know what ill need to hook up ypvs up because right now it is only run on the ypvs cylinders.thanks
  19. where should i look for parts does it all have to be from rz 350,it would be cool if u could post thx
  20. can someone help me out with how do i rigg up serva and rest to run powervalves,it runs right now but i have no cables and servo motor and batter can some who did this with banshee wireing email me please at gerry_hache@hotmail.com thanks
  21. hey can u get me pics it runs but iam goin to rebuild cause have 50 psi in one cylinder,i bought bike couple yrs ago and it had ypvs cylinders but the power vavle is not hook up ,if u could help with pics of someone who did this would be nice thanks gerry
  22. can anyone email me pics of wireing and pic of ur bikes how u did thanks.
  23. does anyone have how to wire it and what all do i need and where i get cables and other stuff,thanks
