Arizonaduner Posted January 18, 2009 Report Posted January 18, 2009 21cc domes, used three times, great condition. These domes are for a 68mm Cub cylinder and have standard squish band/dome profile. $35 includes shipping to lower 48 U.S. Will ship elsewhere but cost will be dependent on shipping. PM me for additional pic. Steve Quote
2001Stroker Posted January 18, 2009 Report Posted January 18, 2009 Big Bore, and Small Bore will both fit 68mm bores. Which ones do you have? Small fits 64-68 Big fits 68-69.5 I know 1baddshee is looking for some small bore, stock stroke 20's or 21's. Quote
jasons Posted January 18, 2009 Report Posted January 18, 2009 21cc domes, used three times, great condition. These domes are for a 68mm Cub cylinder and have standard squish band/dome profile. $35 includes shipping to lower 48 U.S. Will ship elsewhere but cost will be dependent on shipping. PM me for additional pic. Steve i have been looking for these for a while. know that found them these won't work on my jugs. my bore is 65.50. i wish they worked good luck with the sale. Quote
Stellar Performance Posted January 18, 2009 Report Posted January 18, 2009 Big Bore, and Small Bore will both fit 68mm bores. Which ones do you have? Small fits 64-68 Big fits 68-69.5 I know 1baddshee is looking for some small bore, stock stroke 20's or 21's. Just a heads up....small bores will not work on a 68mm bore, the oring is exposed in the cylinder. Small bores should only be used up to 66.50mm. Anything larger should use big bore domes. Quote
Arizonaduner Posted January 18, 2009 Author Report Posted January 18, 2009 Just a heads up....small bores will not work on a 68mm bore, the oring is exposed in the cylinder. Small bores should only be used up to 66.50mm. Anything larger should use big bore domes. I guess he answered the question (I wasn't sure but I knew who to ask) they are big bore domes. Quote
jasons Posted January 18, 2009 Report Posted January 18, 2009 I guess he answered the question (I wasn't sure but I knew who to ask) they are big bore domes. so these will not fit my head. just want to make sure i am reading this right. because a couple have saidit will work. thanks Quote
2001Stroker Posted January 18, 2009 Report Posted January 18, 2009 Just a heads up....small bores will not work on a 68mm bore, the oring is exposed in the cylinder. Small bores should only be used up to 66.50mm. Anything larger should use big bore domes. Thanks, Tim. I could've sworn that Pro-Designs site said they would work. Oh well. Learn something new everyday. Quote
dlnoss Posted January 19, 2009 Report Posted January 19, 2009 Pro Design must use different language to describe their domes than I do. I don't really refer to any of my domes as 'big bore' domes. I just made some 85mm bore Sabre domes,,,,that's big bore. My 'standard' domes are for Banshee pistons up to 66mm bore. My 'Cub' domes, the ones engraved 'Cub 20', etc., are for 68mm bore, Blaster piston. My custom domes will usually be engraved something like 19 13 047 meaning 19cc, 13 degree squish area, and 0.047" squish step in the dome. If someone is buying a big bore dome, or any dome for that matter, they should be sure the squish angle (or sometimes the squish radius) matches the pistons they are using. .....Just a little info. -David Quote
05.Banshee.SE Posted January 19, 2009 Report Posted January 19, 2009 Off topic here for a second - but what is the "#" over on the stock jugs to reach 68mm/421cc? (10/20/whatever) Quote
dlnoss Posted January 20, 2009 Report Posted January 20, 2009 I don't understand the question if it's a question for me. -David Quote
