Everything posted by Arizonaduner
421cc Cub Banshee FS - Tucson, AZ - $4300
Arizonaduner replied to Arizonaduner's topic in For Sale - Parts & Accessories
Still FS - Will be at Ogilby (Glamis area - across from Buttercup) from Feb 6th - 8th. Not riding Banshee, riding another bike. Test rides OK with money in hand. 1996 Banshee -421cc Long rod motor -Aftermarket Cub cylinder -Hotrods crankshaft +4mm (Welded) -Shearer in-frame pipes -35mm PWK carbs -Vforce3 reeds -Billet Aluminum intake manifolds -Noss Coolhead w/19cc domes -Adjustable timing plate(Set at +5 -
FS - 21cc Domes For Noss/Prodesign Coolhead
I guess he answered the question (I wasn't sure but I knew who to ask) they are big bore domes. -
Bump - Still FS. -
No luck yet. I've talked to several people lately and sand toys just aren't selling much. It didn't help that I first put it up for sale in mid-summer (Off of dune season). I did have one solid offer for $4K the first week I had it FS but I turned it down. I wish I would have taken it now. A year ago I could have probably gotton $4800-$4900 but who knew the economy was gonna tank. O'well. It's a good bike. I'll keep at it. Steve -
Found a picture. E-mail me for more if interested. Steve Sahuarita, AZ [email protected] -
Will be at Glamis over New Years (Sunday 28th - 1st). Test rides OK with money in hand. Wash 2 Sunday/Monday but switching camp over to Gordon's Well on Tuesday the 30th. 1996 Banshee -421cc Long rod motor -Aftermarket Cub cylinder -Hotrods crankshaft +4mm (Welded) -Shearer in-frame pipes -35mm PWK carbs -Vforce3 reeds -Billet Aluminum intake manifolds -Noss Coolhead w/19cc domes -Adjustable timing plate(Set at +5
Heading down Sunday 27th, Wash 2 but switching camps to Gordon's Well on Tuesday. Plan is to stay thru the 1st. My 96 Cub cyl Banshee is for sale - $4300. Test rides available if you've got money in hand. Steve 520-730-5599
X-mas break, especially New Years gets kinda busy but after that it's not too bad. Once you get out away from the camping areas/olds hill you hardly see anybody.
For Sale - Here's the hardware description: 1996 Banshee, 421cc Long rod, Cub cylinder, Shearer pipes, 35mm PWK carbs, V-force reeds, +5 Swingarm (W/skidplate mounts), Noss Coolhead w/19cc domes, Adj timing plate, Works rear shock, 20x10x10 Hauler Extreme paddles, Brand new top-end (Plating, Pistons, Rings, & Wristpins) & one season on bottom-end, Very fast (~90hp) & very well maintained, All receipts, Folding ATV ramps & dirt tires included. Here's some extra info: The bike is setup to run the big bowls at Glamis. It's a fast play bike (Really fast). It could be setup better for straight-line drag with a little work (Longer swingarm - more tire) but as-is is a good compromise between turning ability and "Out of the hole" traction. You would be hard pressed to find a bike that could run the bowls faster than this bike and you'll still beat just about ANY 4-stroke up the sand drags. I had a custom rear grab bar made up to be just big enough to hold a 1gallon gas can. That way you can take long rides with your 4-stroke buddies (As they're eating your roost). I hate to get rid of it, but I need the money. Parts and guidance came from Racer's Edge-AZ. Selling for $5000. PM me for more pics if you're interested. Steve 520-730-5599
I'll PM you.
Almost forgot. Is the water pump seal good?
How's the water pump contour look? Any grooving?
I'd like to buy a used clutch sidecover (Stock). The waterpump contour on mine got chewed up from a previous owner installing a billet impeller. Let me know what you have. Thanks, Steve
What's the best way to clean clutch friction plates? I had some coolant in my tranny oil and I've heard it can degrade the clutch friction material. I didn't notice any clutch slipping before and I think I've corrected the problem but I'd like to try and clean up the friction disks if possible.
Thanks for the input guys!
I bought a + Swingarm from Quad Customs and even thru some mis-communications on both our parts, Lance stood behind his product. Good quality product at a great price. Would highly recommend!
Thanks Gary. I had a good transaction with Braxton. Would do again. Steve
If you find out ~ what time on Saturday everyone is going out to the flag pole, let me know. I'll meet up with ya.
Flo Jo, Where you gonna be? I assume Glamis? I'll be there Thursday night thru Sunday afternoon. I like the :beer: part
I just got my 421 Cub Banshee running. I bought a used Works rear shock and the tail is now sitting sky high! The previous owner of the shock had a +6" swingarm and I've got a +5 . My question is what would be a good starting point for a dune setup as far as rear ride height and sag. With my 200lbs on it, it's now at ~2in sag. It seems excessively stiff. I'll mostly be riding at Glamis, play riding 70%/hillshooting 30%. Thanks, Steve
It's kind of a long story but will a 45T sprocket interfere/contact with a stock skidplate? Thanks, Steve
I'm up against the fence on this one. I ordered a set of 20x10x10 9 paddle Xtremes's and I'm wondering if I should have went with 22x11x8-9's (I already have a set of 10" rims - That's the main reason I went that way). I haven't taken delivery of the tires yet and I've got a good relationship with the shop I ordered them from (And they've got a ton of sand tires). They might let me swap tires if I ask. Anyway, I've got a +4mm Cub motor that I just built and I haven't ridden it yet. 35 PWK's, Shearer pipes, and a +5 swingarm. I like going fast and hillshooting but I think I like value running the bowls and cutting turns more. I've heard that the 20x10x10's turn and slide a lot better than the 22x11x8's but the 22's have a lot more traction. I've got a guy telling me I should definately go with the 22's. If I go with the 20x10x10's am I just gonna "Sit and spin?" Is there a good in-between tire? Any thoughts? Steve
What To Do With Tors Connectors, 35mm carb install?
Arizonaduner replied to Arizonaduner's topic in Banshee Repairs and Mods
So the Tors system won't disable the ignition if I just leave an open circuit? How exactly does the Tors system work? Steve -
Thanks guys, I smeared just a light coat of RTV on the base gasket. We'll see soon.....
