I am working on a complete Banshee parts list, of what will fit other ATVs, as well as what years have interchangable parts
If you would like to help, please feel free to post here, and I will confirm, and update the master list in this original post
Frame:
J-arm: 1987-1990
A-arm: 1991-2006
CDI Box:
2GU-50/2GU-51: 1987-1994
3GG-00: 1995-1996
3GG-10: 1997-2006
Wiring harness:
round style: 1987-?
square style w/ clear CDI plug: ?
square style with gray CDI plug: ?
On/Off handlebar lightswitch:
round style: 1987-1994
small square style: (with sharp corners) 1995-2001
large square style: (with rounded corners) 2002 - 2006
*each wiring harness style is also specific for headlights, on/off light switch, key switch,
*coil will fit any year
*taillight will fit any year
Stator:
round style - 1987-1994
square style - 1995-2006
Rims/Wheel:
Rear 4/115 bolt pattern - 1987-1988 & 1991-2006 - Banshee, Warrior, Raptor, YFZ450
Rear 4/156 bolt pattern - 1989 - 1990
Front: 4/156 bolt pattern - 1987-2006 Banshee, Warrior, YFZ450, Raptor
Rear Sprocket:
1987-1990 - 4 finger style hub
1991-2006 - 6 finger style hub
* axle will fit any year
* brake hub will fit any year
There is an oddball year wiring harness that wont fit any other year. I just checked 1994, 1995, 1996, and 1997 and they all have different part numbers for each year. I just cant remember which year is the weird one.
also, does anyone know if the 2 different style carriers will fit any year swingarm?
this is nice and all, but Im not contributing for someone elses profits that have sold myself and others garbage, which Im certain this is actually about.
Ouch!Ithink that was a little harse, I have got alot parts in the past from him and he aways did me right .
Edited by R/C Hippie
fuck i hope its not 97, i have one! didnt the headlights change? the actual reflector/glass part look different on my 97 than my 06, and the 06 headlights work way better! the connectors are also different.
Edited by official_style
uh-oh, mines a 97. i'd like to know too, but i think i remember it bein the first year of the newest as far as plugs and cdi, but not 100% on that
  • 2 weeks later...
  • 1 month later...
The 95, and 96 model years had the different style plugs on the stators, and CDI boxes, which makes them more expensive. I've got a 96, and when I replaced my CDI, it cost me some $$$$. :down:
Correction, the 1995 and 1996 have a different plug on the CDI only. So for CDI, you have 87-94, then 95&96, then 1997 on up. Stator would be 87-94 and then from 1995 on up. FYI, the CDI will work just fine if you change the plug to whatever style harness you have. In other words you can buy a CDI for another year bike and put your plug on it to make it work. I did this for my 95. Keep in mind the newer CDI boxes have the parking brake interupt and you need to deal that wire if you put that stator on an older bike or a bike with no parking brake
