Yup, a little. Just moving along. I keep forgetting to bring the camera to work to post pics. Since my last post I've built a better powder coating booth, powder coated most of the small parts a burnt translucent orange (very pretty). It's my first time doing a translucent color and I'll tell you, it's a lot harder to get even looking coverage than a solid color. This last weekend I started making the sub frame just because the other one was slightly tweaked. And the one I'm making will just look better. This up coming weekend I hope to finish the subframe and get close to finishing the swingarm I haven't started on yet. The cylinders are being sent out for machining and porting this week. I'm about to a point of having to spend money to get parts coming in.
I already started taking the motor apart so I can sell my cylinders, coolhead, and intake. My target is to have assembly going good by end of February to mid March. I think the most time consuming is going to be getting all the electrical put together and getting everything to actually work.
I'll post pics as soon as I can remember.
  • Replies 41
  • Created
  • Last Reply
Top Posters In This Topic
The way it's going right now I might just have to cut up my procircuits to fit temporarily. Hell, they might even look ok. I just don't see me having the time to make pipes.
that other guys (airtite?) with the cut and shut DG pipes looked awesome.
so your using RZ cylinders? are you going to use the zeeltronic set up?
www.zeeltronic.com
www.zeeltronic.com
Yes. For the price and what you can do, can't really go wrong.
Here's a couple pictures.
Some of the powder coating I did last weekend. Like most pictures of PC'ed jobs, they don't show how good it really looks.
Then what I have done so far with the sub frame. I need to add 3" to it, make some weld in adapters to mount to chassis, and add to the seat mounts. So far it is just tacked in place except for the flag mount.
  • 2 weeks later...
Finally made a little more progress this weekend. The swingarm and subframe are pretty much done. I am thinking about having something laser cut to put in the open space between the bars on the swingarm. Cylinders are finally out for porting and I got my cases washed and ready for powder coat. The swingarm has a honda carrier and I'm going to use the rear brake from one also so it is a dual piston.
Battery box cut out on this one
  • 4 weeks later...
I thought I'd just start adding the motor pics and mods to this forum and leave all the powder coating appearance stuff for that forum. A couple pictures from when I was putting the new 4mil crank in. I put a max load bearing on the clutch side for a little extra insurance, I hope.
Some F.A.S.T. goodies!
Was able to get the basket on. The fibers were soaking in oil. Didn't feel like getting the woodstove going to keep my hands from going numb so this is it till the weekend.
Not a big fan of orange . but this color is sick! good luck on your build, looks like you got everything on lockdown as is tho. i wanna see how the pipes fit, or if you are making your own.
The orange looks much better when outside and in the sun. Doesn't look so orangy. As for the pipes, I plan on modifying my pro circuits to fit because I'm just not going to have the time to make my own right now before riding season. I'm getting anxious though. Still shooting for around the 1st week of April to fire it up.
  • 3 months later...
