I use a shift cam with the bearing modification. Trinity sells the same thing for $129.99, and it has been fine for me.
Alba's $149.99 is not such a crazy, low price after all! :blink:
what do you mean by bearing mod?
The stator side of the shift cam is machined down, and a bearing is installed. The shift cam will have a bearing on each end just like it should have had from the factory. :huh:
The modification is not going to be the fix all, solve all of transmission/shifting problems, but it does allow the shift cam to spin very easily...
EDIT: The modified shift cam, modified shift star, and modified shift shaft will be a huge improvement in transmission performance (assuming things are not worn or damaged) over stock. You do not necessarily need the shift pro modification. I would inspect the shift adjust bolt and replace it if necessary while the basket is removed...
i never had issues with shifting before but i got one of those Yakkey racing shift drums just to try it out. i didnt notice anything special. and for the cost of that, you can just have yours done and save some $$$
Yep, I've done my own accept I use a needle bearing instead of a ball bearing. Easy to do if you have access to a lathe. Along with the other tranny modes I have done it does make a nice difference though. $150 is a crazy ass price though. Is that for the shift drum or do they want yours as a core?
SP
