Guest utleybanshee Posted January 6, 2009 Report Posted January 6, 2009 cracked my case about a month ago... just starting to investigate.. what do you guys think happened?? Any input would be greatly appreciated.. Quote
jbooker82 Posted January 6, 2009 Report Posted January 6, 2009 I would say it was started by a chain break and the crack grew. Or the roughness of the metal allowed stress to build up and form a crack. That is why all your conecting rods in drag engines are pollished smooth. There is no rough castings for a stress riser to occure and lead to a failuer. Do you have all of your motor mounts tight, including the bottom ones? josh Quote
shanYE west Posted January 6, 2009 Report Posted January 6, 2009 I agree.. I think it started with the chain break.. then engine vibration took over and finished the job.. Quote
BlasterKX Posted January 6, 2009 Report Posted January 6, 2009 this might be wrong but have you been hitting jumps latly? if so maybe ur chain was alittle tight when hitting the jumps and coming down and pulling on the sprocket which will put pressure on ur case?maybe idk just a guess cuz my buddy did that exact same thing on a blaster Quote
peterlocal22 Posted January 6, 2009 Report Posted January 6, 2009 pretty sure it was like everyone said, chain Quote
BUILDER Posted January 6, 2009 Report Posted January 6, 2009 I agree it was the chain. When you put that thing back together make sure you get a case saver on it before that happens again Quote
banshee_terror_ Posted January 6, 2009 Report Posted January 6, 2009 yah that happined to me before. i was riding and the chain fell off and got all binded up in the area between the front sproket and the case and stuff and it snaped Quote
Guest utleybanshee Posted January 6, 2009 Report Posted January 6, 2009 I agree it was the chain. When you put that thing back together make sure you get a case saver on it before that happens again its a drag bike has never seen a jump... and front sprocket is an 18 to big for a case savor... but i was thinking the chain was too tight.. it happened after a launch.. i launched in a lil bit of sand then spin spin spin.. grip and i heard the crack.. so i was guessing the chain was too tight.. Quote
BUILDER Posted January 6, 2009 Report Posted January 6, 2009 [its a drag bike has never seen a jump... and front sprocket is an 18 to big for a case savor... but i was thinking the chain was too tight.. it happened after a launch.. i launched in a lil bit of sand then spin spin spin.. grip and i heard the crack.. so i was guessing the chain was too tight.. That is a nice looking bike! If you launched in some sand and then hooked really hard it would not have made a differance how tight your cahin was i dont think. If you hooked that hard then i am sure thats what did it but it does look like the case was already week from a chain break. Quote
NYUK Posted January 6, 2009 Report Posted January 6, 2009 the output shaft twisted because the chain was too tight. you might want to look into a bearing support, and leave a little slack in the chain. after you install new cases. Quote
shanYE west Posted January 6, 2009 Report Posted January 6, 2009 also.. probably should consider some straight cuts in 2.68 ratio or less so you can use the smaller sprockets and a case saver... Quote
Guest utleybanshee Posted January 7, 2009 Report Posted January 7, 2009 also.. probably should consider some straight cuts in 2.68 ratio or less so you can use the smaller sprockets and a case saver... ok then i never thought of that.. thanks.. Quote
moneybags Posted January 7, 2009 Report Posted January 7, 2009 You should beable to rig then cases up to work like new.... Quote
lunatic Posted January 7, 2009 Report Posted January 7, 2009 The whole area has a big piece missing from previous damage. Unless some one cut it out for the heck of it. Its pretty obvious a 4" piece is gone. Did you buy it this way or did you modify the cases? Quote
