i have a 421 cub that i am setting up for draging, it is not ported and not sure if i am going to run gas or alky. i have cpi inframes right now. would shearer out of frame small bores be better than the cpis or would the shearer inframes be better? whats your thoughts thanks
there seems to be a pretty fine line between small bore and big bore on the 421 cub motors.. i would say if youre gonna run out of frames to run small bore..
who is your builder?
the motor is not ported, i got it from a guy who had rudy kurtzy put it together. then i had a friend at gbracing put a duneable trans and a slingshot in it. dont know what the domes are it has vf 3 reeds and came with 38mm pj carbs. im undecided about having it ported since i have never did any drag racing or even had a cub till know. what do you think
I would say small bore for a non ported 421. If it's strictly drag then go with the oof's. The shearers are worth a bit more power, but at the expense of some midrange power.
its going to be a drag play bike
