regalrocket Posted December 9, 2008 Report Posted December 9, 2008 I was wondering if you use one of the neutral switches from FAST, do you just replace the stock cover plate with the switch plate, and thats it or do you have to do more work? I am just curious if you could toss on a neutral light or not, Thanks. Quote
LS1Inferno Posted December 9, 2008 Report Posted December 9, 2008 I was wondering if you use one of the neutral switches from FAST, do you just replace the stock cover plate with the switch plate, and thats it or do you have to do more work? I am just curious if you could toss on a neutral light or not, Thanks. swell its the same thing its just there because the RZ had them you need the stuff that goes inside. Quote
BenBB Posted December 9, 2008 Report Posted December 9, 2008 I'm pretty sure all you'd need to do is tap onto the yellow wire (for lights, assuming you have the stock circuit) to a bulb, and run a wire from the other side (ground) of the bulb to that terminal on the little white plastic shift drum cover from an RZ or if it has the terminal the FAST one. The RZ just uses one wire so I'm guessing that terminal grounds when you're in neutral, completing the circuit and illuminating the light... Quote
