BansheeRider87 Posted December 9, 2008 Report Posted December 9, 2008 we know yfz from arms and shock fit the shee. What other kinds of parts fit the banshee from other yamaha quads? Axles? stock rims? Quote
klemet banshee Posted December 9, 2008 Report Posted December 9, 2008 raptors banshees yfzs and warriors have the same bolt pattern Quote
BansheeRider87 Posted December 9, 2008 Author Report Posted December 9, 2008 (edited) raptors banshees yfzs and warriors have the same bolt pattern Metriccccc 10,12,14 most common Edited December 9, 2008 by BansheeRider87 Quote
05.Banshee.SE Posted December 9, 2008 Report Posted December 9, 2008 Yes, rims too. I run YFZ450 front rims, due to my casing the rock in the ride of shame thread. (Found 'em for sale the next day.) Quote
BenBB Posted December 9, 2008 Report Posted December 9, 2008 Blaster & Banshee axles interchange, easy way to gain 2" on a Blasty but you'd be goin' -2" the other way. Banshee & YFZ450 front brake master cylinder and calipers are direct bolt-ons, YFZ450 lines will work even with +2 a-arms although the tee mount doesn't match up exactly it'll work. I'd bet Raptor and Warrior are the same, although single piston like Banshee and not 2-piston like the YFZ. There's the Blaster pegs thing too, 2" back and a little lower, I think Raptor pegs are similar. Oh hey intakes and crossover tubes/boost bottles interchange from Banshee to RZ350 along with a couple other items :happy: Quote
AKheathen Posted December 9, 2008 Report Posted December 9, 2008 I'd bet Raptor and Warrior are the same, although single piston like Banshee and not 2-piston like the YFZ. huh? Quote
Trick2stroke Posted December 9, 2008 Report Posted December 9, 2008 huh? He's talking about the brake calipers, the banshee, blaster, raptor, warrior all have single piston brake calipers, the yfz has dual piston calipers. I believe the stems interchange but they're different lengths, I think people were putting worrior or banshee stems on their blasters for + lengths. The spindles all interchange also I believe.... There's quite a bit that interchanges. Quote
AKheathen Posted December 9, 2008 Report Posted December 9, 2008 He's talking about the brake calipers, the banshee, blaster, raptor, warrior all have single piston brake calipers, the yfz has dual piston calipers. I believe the stems interchange but they're different lengths, I think people were putting worrior or banshee stems on their blasters for + lengths. The spindles all interchange also I believe.... There's quite a bit that interchanges. oh yah, duh.... caliper piston, was thinkin engine for some reason :shoothead: Quote
fastrthnu Posted December 9, 2008 Report Posted December 9, 2008 some polaris quads have the same front bolt pattern Quote
AKheathen Posted December 9, 2008 Report Posted December 9, 2008 some polaris quads have the same front bolt pattern polaris, ha ha :yelrotflmao: the historically polar opposite of yamaha. not talkin about parts, just mentioning polaris made me think about how yamaha hasn't built a decent sled untill recently, and polaris just needed to stick to sno-go's. but recently, anything goes- a little off subject Quote
2strokecook Posted December 9, 2008 Report Posted December 9, 2008 Correct me if i am wrong but i believe banshee axle housing also goes on a warrior. Quote
Wiz Posted December 10, 2008 Report Posted December 10, 2008 (edited) old school tri-Z three wheeler axle is the same as a banshee also. Also the warrior rear brake disc will fit a banshee and OEM price is about half of the cost of a banshee one. Also in 04 when I built a new bike I wanted to buy a new factory banshee frame. this is when i worked at the dealership, a stock 04 frame was like $780 retail, I was diggin through the computer and found that a 04' limited edition frame which is exactly the same except black instead of silver was less than $500 retail. I am sure yamaha caught this eventually and you would have to know your dealership guys really well for them to do something like this but it made me laugh. Also I needed a CDI after doing some digging again (the previous thing tought me) I found that you could by the GYTR performance CDI for like $100 cheaper than the stock unit. I have the GYTR unit now and have swapped it on several bikes and can be damned if I can tell any difference, but it was cheaper, smaller and mounts better (comes with a bracket). Plus it comes with a GYTR sticker on it...that scares the shit out of the guy you are linning up with....lol I also came across a small aluminum kickstarter, a friend foud out on the sand it got threw into a box of misc. parts I ran across it while building my last bike and did some comparing to find out that it fit a banshee knuckle perfect, it is trick looking follows the clutch case lines real well and is kinda a 1 off on my bike, no clue what it is off of, I had it polished and the knuckle chromed, I will take a pic mayby somebody can recognise what it is off of. Edited December 10, 2008 by Wiz Quote
Wiz Posted December 10, 2008 Report Posted December 10, 2008 it was the polaris scrambler front wheels that were the same bolt pattern as a banshee also. my dad had one of those POS 400 2 stroke scramblers that we put paddles on all 4...what a dissapointment that whole bike was.... Quote
BansheeRider87 Posted December 11, 2008 Author Report Posted December 11, 2008 what about shocks? they the same? Quote
