rajaa11 Posted December 8, 2008 Report Posted December 8, 2008 Hello I'm looking for the rod and bearing that goes inside of the clutch, my adjuster and pusher lever are ok. As you can see my bearing and rod welded it self together and now my rod is too short. I have the pancake bearing mod on its way I just need the rod. Let me know a price for everything, I'm in Fort myers florida if any one is close by. Thanks Quote
RUDEDAWG Posted December 8, 2008 Report Posted December 8, 2008 Hello I'm looking for the rod and bearing that goes inside of the clutch, my adjuster and pusher lever are ok. As you can see my bearing and rod welded it self together and now my rod is too short. I have the pancake bearing mod on its way I just need the rod. Let me know a price for everything, I'm in Fort myers florida if any one is close by. Thanks You will most likely need the ball also, A good place to get the whole setup from would be jeff at farmandsandtoys.com He is also a sponsor on here. Quote
jbooker82 Posted December 8, 2008 Report Posted December 8, 2008 Here you go. 8 bucks for the rod and a dollar for the ball. http://67.199.65.66/cascade_innovations/ne...ORE_DEPT_ID=358 When you get tired of replacing the ball and rod buy cascades pancake berring. It replaces the stock adjuster in the pressure plate. It has a flat roller bearing so you dont weld the ball and rod. I believe jeff at fast also sell them. Just make sure you get the cascade style because it has notches on the out side so you can hold the adjuster while adjusting it. Other modles have the notches behind the pressure plate. So you have to assemble the clutch and adjust it. Then take it appart so you can hold the adjuster while you tighten it down. Quote
