00superdave00 Posted December 5, 2008 Report Posted December 5, 2008 I have an 05 banshee and when you first start it up shee doesn't like to idle, you have to constantly give it some gas to keep it running. But once it has been running a lil while it idles fine. Should I be worried? Quote
docjcwatson Posted December 5, 2008 Report Posted December 5, 2008 I am going to guess that you live somewhere cold and haven't re-jetted for winter. A little more info and we can point you in the right direction. Quote
AKheathen Posted December 5, 2008 Report Posted December 5, 2008 I have an 05 banshee and when you first start it up shee doesn't like to idle, you have to constantly give it some gas to keep it running. But once it has been running a lil while it idles fine. Should I be worried? how cod is it? what mods? how hard to start? where are your airscrews set at? you may be lean for the temp. if so, move the needle 1 clip twards the point of the needle. but first, sync your carbs. and always resync them whenever you pull the slides out. Quote
MikeNick Posted December 5, 2008 Report Posted December 5, 2008 how cod is it? what mods? how hard to start? where are your airscrews set at? you may be lean for the temp. if so, move the needle 1 clip twards the point of the needle. but first, sync your carbs. and always resync them whenever you pull the slides out. Your supposed to resync them every time you take them apart????? OH SHIT Quote
wesw Posted December 5, 2008 Report Posted December 5, 2008 turn your air screws in or put a bigger pilot its lean. Quote
AKheathen Posted December 5, 2008 Report Posted December 5, 2008 Your supposed to resync them every time you take them apart????? OH SHIT just good practice, you'll know they're right and know instantly if one's in wrong. :thumbsup: Quote
locogato11283 Posted December 5, 2008 Report Posted December 5, 2008 i agree with wes.. try air screw.. if necessary bump up the pilot. Quote
00superdave00 Posted December 5, 2008 Author Report Posted December 5, 2008 I just got the bike not to long ago and all i can tell is pipes and boost bottle, I live in Virginia, and the guy I bought it from lives here also, its not that cold around here, i rode it when it was still warm outside and it still did it until the bike was warm. What do you do to sync the carbs? What do you do to re-jett it? Quote
banshee_terror_ Posted December 5, 2008 Report Posted December 5, 2008 its beacause the bike is cold. see when it first starts it sends radiator fluid straight through the motor and it cools it down rate away. and its hard for the motor to keep combusting. so when u get the radiator fluid hot and warm it will idle fine it should at least. Quote
docjcwatson Posted December 5, 2008 Report Posted December 5, 2008 First. You are going to need some new intakes. I am willing to bet that your boost bottle has something to do with your currently lean condition. You can get those here ... http://www.farmandsandtoys.com/partdetail.asp?partid=190 ... Exspensive? A little, but you'll never have to worry about buying another set ever again. Then, you need this ... http://www.farmandsandtoys.com/partdetail.asp?partid=59 ... Which will help you out immensly. Then you should come back here and tell us what's up. Quote
wesw Posted December 5, 2008 Report Posted December 5, 2008 its the temp of the air coming into the motor coolant temp wont help it if its -5 below and your bike is 180 degrees its going to be really looking for fuel cause the air charge will be very dense meaning lot of oxygen. to sync watch this http://www.bansheehq.com/forums/index.php?showtopic=95025 Quote
00superdave00 Posted December 5, 2008 Author Report Posted December 5, 2008 After it warms up there is no problems, is this typical or a problem? Quote
AKheathen Posted December 5, 2008 Report Posted December 5, 2008 diggin the new avitar wesw :beer: on the top right of each carb, there is a little window (about 1/4" round) when you bring it up to wide open, silver dots should appear at the same time. if not, adjust the cables so that they do (push in the metal stem while you turn the screw) next, they should stop at the bottom at the same time. adjust with the idle screws. make sure the air screws are the same number of turns out, usually 1.5 turns out. i'm guessin that whoever put the pipes on, didn't re-jet it afterwards. find ou what they are and get back to us, or go to the website for aproximate jetting. but ther is probably a post in the jetting and exhaust forum that already answered that question, so do a search. Quote
firebanshee Posted December 5, 2008 Report Posted December 5, 2008 You could just leave the choke half way out until the bike is warmed up,i have to do this on cold days.I think that is what that half way detent is for on your choke. Quote
AKheathen Posted December 5, 2008 Report Posted December 5, 2008 You could just leave the choke half way out until the bike is warmed up,i have to do this on cold days.I think that is what that half way detent is for on your choke. mine doesn't stay verry long, but i used to hold it and put along a bit. Quote
