firebanshee Posted November 22, 2008 Report Posted November 22, 2008 Does anyone know how much a stock banshee a arm frame weighs stripped with no a arms or swing arm or anything else on it ? Quote
Fearnot Posted November 30, 2008 Report Posted November 30, 2008 I am almost certain it is 56 pounds with all the tabs on it I haven't seen the number in along time but that's what I remember it as. Quote
2001Stroker Posted November 30, 2008 Report Posted November 30, 2008 I just weighed mine last night with my digital fish scale. 43 pounds, 11 ounces. EDIT: That's with all the unneccessary mounting tabs cut off. And thy're only about 1 pound, at most. Quote
Stellar Performance Posted December 1, 2008 Report Posted December 1, 2008 Stock a-arm frames with everything unbolted weigh in at 46 pounds. Quote
2001Stroker Posted December 1, 2008 Report Posted December 1, 2008 Stock a-arm frames with everything unbolted weigh in at 46 pounds. Damn, hard to believe that I cut off more than 2 pounds worth of mounting tabs. Quote
joee20002 Posted December 9, 2008 Report Posted December 9, 2008 mine was 49 lbs stock un touched and then after lighten by tyson it is 31lbs Quote
2001Stroker Posted December 9, 2008 Report Posted December 9, 2008 What the hell did you get cut off? 31lbs? There ain't ANY brackets left on mine, except the rear fender brackets, motor mounts, and a-arm and shock brackets. 1 Quote
