NEWS UPDATE.....Took the TORS out and NADA! Bike still all weirded out! It revs and idles fine, i put it in first geaer and it rides but after about 1/4 throttle in, its starts to bog out (when it starts to bog out, it makes the sounds as if the bike is all choked out) and doesnt doesnt go any faster.......
Have you ever taken the slides out of the carbs? Also check to see if your choke tube is conected between the carbs.
No, i havent played with the carbs since i jetted it like 2 years ago. I pulled the choke tube back and forth, but i didnt check to see if its connected correctly or not. I just thought it was working fine. I think i Should i just completely take out my carbs and clean them.... Hopefully something came loose in there and its not anything big. Ill do that today and ill let you know what happens...... Anything in specific i should keep an eye out for that could be causin my problem beside the slides??????
Try cleaning the hell outta the carbs. A piece of grit will cause a load of problems. Take them off, spray them out with carb cleaner and blow them out with an air hose. Make sure you take out the jets and clean them out good.
+1 the biggest problem to us banshee guys its dirt, sand, and mud. they will cause more problems then you would imagine
