bansheeMO
About bansheeMO
  • Birthday 02/09/1984
    Los Angeles
    Black on black 2001 twin 250. TMY tr6, k&n, Pro-x Piston, boost bottle........
bansheeMO's Achievements
  1. No, i havent played with the carbs since i jetted it like 2 years ago. I pulled the choke tube back and forth, but i didnt check to see if its connected correctly or not. I just thought it was working fine. I think i Should i just completely take out my carbs and clean them.... Hopefully something came loose in there and its not anything big. Ill do that today and ill let you know what happens...... Anything in specific i should keep an eye out for that could be causin my problem beside the slides??????
  2. NEWS UPDATE.....Took the TORS out and NADA! Bike still all weirded out! It revs and idles fine, i put it in first geaer and it rides but after about 1/4 throttle in, its starts to bog out (when it starts to bog out, it makes the sounds as if the bike is all choked out) and doesnt doesnt go any faster.......
  3. Thats awesome...where can i buy the Vac from?
  4. So i dont need a kit then right...following the instructions will do...... My carbs have already been drilled from when i put the twist throttle on and Im not worried about removing the carbs faster...... Alright...Removing the TORS today and hopefully my baby will come to LIFE!
  5. Agreed with the mud flap comment... Thats gotta go SON! I dont think its protects anything at all anyways! Aww i miss my baby...Hopefully it will back and running soon!
  6. Will do when i get of work....Thanks for all the help...i appreciate it.... One more question before i remove the TORS later today...do i need a KIT or will the cutting (following the instructions from the thread) do just fine?
  7. How does the bike act when the TORS are acting up..... can you give examples because i think i might be having a prob with my TORS..... I put up a thread "engine problem" this morning seeking help and the homies lead me to your thread... Thanks
  8. Do you really think its the TORS and not something else? I wish you guys were close to LA (cali) so you check out my ride. I guess ill start by removing the TORS and take it from there..... I dont need the TORS anyway right....
  9. Yes, I do! i took them off a few years ago when i installed a twist throttle, but i didnt like the twist system so i put everything back...
  10. Looks Sick!.....I think a Shee with cut front fenders looks way sexier than stock. My baby rocks cut fenders too!
  11. It's not the rear brake.....i can push and move my baby around when its off and in Neutral. I wish wish it was something as simple as that!
  12. I was thinking it might be my carbs because it seems like my left is working harder than my right side (more white smoke from the right exhaust than the left).... Im scared that i blew a piston or a ring on the right piston? if a piston was blown or if the piston ring was torn, would the bike start???? But if it was my carbs, it wouldnt idle or rev normally on neutral would it?
  13. I went riding this weekend and after about 15min of use, my banshee was acting super weird. It wouldnt even run past 5MPH in any gear..... I always use yamalude 2r on my SHEE...but this weekend i ran the 2s on accident. I didnt even ride it for 15min before it started acting weird.....almost like if it was choked. I got home and drained all the gas, replaced it with yamalube 2r. I changed out the trans oil and drained and refilled the radiator fluid. I replaces the plugs. Heres the weird part...... i turned it on and it sounds fine, it idles fine, but once i put it to gear and try to ride it, it bogs out. Its smoking more that usual too.... I have no idea what else to do. I've let it idle for about 10min to make sure all the old gas was out of the system. Any other ideas on what i can do before i take in and they charge me a grip to fix it????? Thanks Moses Any help would be great.....
