OKCterror Posted November 13, 2008 Report Posted November 13, 2008 Do i have to cut the two little rubber flippers on both sides of the intake boots? Was told by the seller i would have to.-Dan Quote
sinisterboo Posted November 13, 2008 Report Posted November 13, 2008 Yep, you cut those ears off. I used a razor blade on mine. Some use a hacksaw cuz its quicker. Quote
OKCterror Posted November 13, 2008 Author Report Posted November 13, 2008 so i just cut it off flush? Quote
sinisterboo Posted November 13, 2008 Report Posted November 13, 2008 yep, make it so if you layed the intake, cylinder side down, on the table, it would be perfectly flat......If not you may have an airleak prob when you're done. Quote
OKCterror Posted November 13, 2008 Author Report Posted November 13, 2008 why are the vf3's not cut for this. Am i going to see a big improvement with the 3's? Quote
locogato11283 Posted November 13, 2008 Report Posted November 13, 2008 yea, cut those things off.. i used a chainsaw on mine. Quote
OKCterror Posted November 13, 2008 Author Report Posted November 13, 2008 ok so my garden shears should do it Quote
locogato11283 Posted November 13, 2008 Report Posted November 13, 2008 ok so my garden shears should do it i dont see why not. Quote
OKCterror Posted November 13, 2008 Author Report Posted November 13, 2008 sweet, its wackn time.lol. that sounds cool. Quote
caddyman Posted November 13, 2008 Report Posted November 13, 2008 Am i going to see a big improvement with the 3's? YES>>>> Quote
XxMeltIcexX Posted November 13, 2008 Report Posted November 13, 2008 yea, cut those things off.. i used a chainsaw on mine. :laugh: Quote
jbooker82 Posted November 13, 2008 Report Posted November 13, 2008 The easiest method is to buy a set of PWK's and a boss intake. NO Cutting Required. Quote
gumby6t9 Posted November 13, 2008 Report Posted November 13, 2008 The easiest method is to buy a set of PWK's and a boss intake. NO Cutting Required. That's exactly what I did! :cool: Quote
