99bansheeworked Posted November 11, 2008 Report Posted November 11, 2008 i got my shee a cupple days ago i check the sparkplugs and all that it has no key and no kill switch the kid told me you have to stall it out. idk if that is bad for it. inaddation i have driven it before but he says i need to crunch the wiress now it wont start i could use your help thank you all Quote
regalrocket Posted November 11, 2008 Report Posted November 11, 2008 i got my shee a cupple days ago i check the sparkplugs and all that it has no key and no kill switch the kid told me you have to stall it out. idk if that is bad for it. inaddation i have driven it before but he says i need to crunch the wiress now it wont start i could use your help thank you all Sounds like someone was tinkering, and F'd the wiring harness up. I know the feeling, mine had a key installed, but they cut the plug off of it and just looped the wires. If your harness is as bad as you say, I would really get one off of e-bay, and properly modify it if you have no TORS and then install it. Quote
travis6767 Posted November 11, 2008 Report Posted November 11, 2008 what do you mean you had to crunch the wires ? all you need to do is find a stock kill switch and plug it in to the wiring harness Quote
T_Shee Posted November 11, 2008 Report Posted November 11, 2008 if you have the two wires for the kill switch together then thats why it wont start. even without a key switch or kill switch you should be able to get it to run (barring any other problems). Quote
99bansheeworked Posted November 11, 2008 Author Report Posted November 11, 2008 no i have it runnig sometimes but it is a pain in the ass alot but like he said to crush the wires idk why and i cant find the kill switch bc htere is none i look where the wires go 2 mrrw thanks for teh input :biggrin: Quote
