99bansheeworked
Everything posted by 99bansheeworked
  1. o you cant order over the intrenet i guess i tell them i from bansheehq i pissed you cant take apart the crank to replace that bearning tho
  2. that puller you put on the flywheel make it easy to remove ya i buy it but i cant seem order stuff off fast performance
  3. umm lawl ok
  4. ya i dont have a flywheeler puller i gues without that i screwed
  5. can somehelp help
  6. so i need put the flywheel puller on one side and turn the other side that is it
  7. no i know the last one is the clutch but i asking that bolt there do i need to take that off to get the crank out ??
  8. i did buy the clymers manunal but just want to ask a cupple questions with this dome does it need a o ring or something on it http://img832.imageshack.us/i/dsc02140h.jpg/ this is the stock dome. i live in new york what a good size cc its dosent have alot mods its has like bassic exhaust intake headers jetted and a bit more http://img836.imageshack.us/i/dsc02141y.jpg/ how do you remove this i gues it would be the flywheele i not sure do you have to remove both bolts like i pointed out in the picture http://img715.imageshack.us/i/dsc02138b.jpg/ http://img828.imageshack.us/i/dsc02139g.jpg/ thanks guy for all your help
  9. thanks man for all the help but is there a how to replace and take out the crank i bought the clymers manunal i try post it if i can. is there a how to split the case i lsoesed the screw at the bottom of the case and no luck
  10. you dont think be easier to put new piston in and hope cleans that way ok i see how much it will cost
  11. i did buy one waiting for it
  12. i cant clean it myself
  13. hey i trying to figure out how to clean the case (i dont know what its called) here a picture http://img529.imageshack.us/i/dsc02107n.jpg/ http://img835.imageshack.us/i/dsc02108v.jpg/ http://img683.imageshack.us/i/dsc02109q.jpg/
  14. http://img801.imageshack.us/i/camf.jpg/ http://img441.imageshack.us/i/crank.jpg/
  15. o really you don't need to remove the bolt on the flywheelie where like the tranmission gear are. i think called the crankcase on one side and the other side where the sprocket thanks for fast response is i take a pic
  16. is there a how to on remove the crankcase can you remove the bolt by the flywheel and the bold where the front sprocket is
  17. they say a good quick rev not crazy for like 10 seconds that it
  18. and how important is that if its ripped like that
  19. still got the crankcase
  20. so i need to get the same pistons then ok .50mm so it be 64.50 ok thanks
  21. hey guys another question what is the domes is it the cover where the piston are? also i see 16cc dome 17 and 18 what the difference? do you need more parts to put a bigger cc on and does it do anything
  22. thanks guys i will do what would make that happen?
  23. wait its teh same how is that .50 and 0.20 are the same so my piston was bored out then
