i got my shee a cupple days ago i check the sparkplugs and all that it has no key and no kill switch the kid told me you have to stall it out. idk if that is bad for it. inaddation i have driven it before but he says i need to crunch the wiress now it wont start i could use your help thank you all
Sounds like someone was tinkering, and F'd the wiring harness up. I know the feeling, mine had a key installed, but they cut the plug off of it and just looped the wires. If your harness is as bad as you say, I would really get one off of e-bay, and properly modify it if you have no TORS and then install it.
if you have the two wires for the kill switch together then thats why it wont start. even without a key switch or kill switch you should be able to get it to run (barring any other problems).
