ive been having problems with shifting at wot. i put a new shifter shaft modded from fast with modded star, and lighter spring.it shifts fine just riding around or if i shift it as soon as it gets in the powerband, but if i let it rev up to high it wont go in the next gear. i tore it down it has a billet basket, but the clutch hub has a bunch of grooves wore in it. thats all i see thats not right. could that cause this problem by not letting the cluch realase like it should. any help would be greatly appriciated
If the inner hub is grooved up yes the clutch will hang up. Get a new one and keep youree clutch soakin so itdoesnt dry till you put it all back together.
