bansheejoel Posted October 23, 2008 Report Posted October 23, 2008 strongly thinking about putting in a 4 mill still. If i put in a 4mill, long rod crank how many cc's would that equal? Quote
dajogejr Posted October 23, 2008 Report Posted October 23, 2008 Joel... At the top of this forum is a cc chart... Stock stroke on a banshee is 54mm. So a 4 mil stroker (regardless of the long rod or not) is 58mm. Pick what your bore size is....that will give you the cc of the motor. Quote
shanYE west Posted October 23, 2008 Report Posted October 23, 2008 Joel...At the top of this forum is a cc chart... There is??? Wheres it hiding? Quote
dajogejr Posted October 23, 2008 Report Posted October 23, 2008 It is the last sticky thread... http://www.bansheehq.com/forums/index.php?showtopic=85931 Quote
bansheejoel Posted October 23, 2008 Author Report Posted October 23, 2008 Joel...At the top of this forum is a cc chart... Stock stroke on a banshee is 54mm. So a 4 mil stroker (regardless of the long rod or not) is 58mm. Pick what your bore size is....that will give you the cc of the motor. crap, i didnt even see it...thanks for the help Quote
BellicoseBanshee Posted October 23, 2008 Report Posted October 23, 2008 There is??? Wheres it hiding? That is funny, you even posted in that thread! :ninja: Quote
POORBOY350 Posted October 23, 2008 Report Posted October 23, 2008 yep that chart helped me out alot. mines a 4mil with 68mm pistons makes it 421 Quote
banshee4mil Posted October 22, 2012 Report Posted October 22, 2012 quick question, 4mil stroker cranks, i measured mine, there only 2mil stroked on each crank,not 4 so they equil 4 mil TOTAL, but you dont add them to figure out cc's bore x bore x stroke x 2cyls, not adding the strokes from each cyl , so why do ppl think a 4 mil is 58?, its 56mil anymore stroke and the cases would need trenched, thats why i went drop in 4mil/5mil long rod, and the rod if you get 795 pistons they bring the tops back where there suppose to be, so its still 2mil stroked like a v8 motor you take the stroker crank- and bor x bor x strk x 8 anyone have any reasoning? lol thanks guys for hearing my rant Quote
banshee4mil Posted October 22, 2012 Report Posted October 22, 2012 retard, you need to shut up. a 4mil stroke stroke adds 4mm to the stroke of a piston. it allowed the the piston to move 2mm farther upward, and 2mm farther downward. also for engine displacment, it is bore/2 * bore/2 * pi * stroke * # of cylinders. call me retard muther fucker, you dont add up and down! you add total, length the (rod "big" pin) is moved in or out on the crank! so fuck you you stared with the names by the way dick, this is how you treat ppl that ask something? your a fucking punk Quote
rubberneck Posted October 22, 2012 Report Posted October 22, 2012 call me retard muther fucker, you dont add up and down! you add total, length the (rod "big" pin) is moved in or out on the crank! so fuck you you stared with the names by the way dick, this is how you treat ppl that ask something? your a fucking punk Is this a joke. :Crybaby: Stroke length is total stroke from BDC to TDC Just so you know 795 pistons compensate for the 115 mm rods. If you have 115mm rods and 795 pistons and the piston edge is level with the deck on stock cylinders (no spacer) you have a stock 54mm stroke crank. On a 4mil (58mm) crank with 115 rods and 795 pistons, the piston edge is 2mm or 0.080" above the deck and requires domes that are recessed the same amount in the head. Quote
banshee4mil Posted October 22, 2012 Report Posted October 22, 2012 must be a joke, cause in the real world you dont add that, just the movement on the pin/flyweight i understand what your saying, but thats not how you do things in motor building it was a simple question Quote
dozer Posted October 22, 2012 Report Posted October 22, 2012 (edited) call me retard muther fucker.... your a retard muther fucker Edited October 22, 2012 by dozer Quote
rubberneck Posted October 22, 2012 Report Posted October 22, 2012 must be a joke, cause in the real world you dont add that, just the movement on the pin/flyweight i understand what your saying, but thats not how you do things in motor building it was a simple question are you serious Quote
banshee4mil Posted October 22, 2012 Report Posted October 22, 2012 your a retard muther fucker boy you are a retarded muther fucker plain and simple, you dont add up and down, the length of the pin moved is all you add,(or subtract) no matter if its 2 stroke or 4 stroke all im going to say, so go fuck your little dick smoking selves get it ? dont bother me again, if you dont like it ask a real builder ignorant fuck face ball lickers Quote
dozer Posted October 22, 2012 Report Posted October 22, 2012 boy you are a retarded muther fucker plain and simple, you dont add up and down, the length of the pin moved is all you add,(or subtract) no matter if its 2 stroke or 4 stroke all im going to say, so go fuck your little dick smoking selves get it ? dont bother me again, if you dont like it ask a real builder ignorant fuck face ball lickers damn this is like jr high all over. your mommas so fat lol. good lord dude calm down. Quote
