Take the top end off and check everything...
Could be either or both of those, plus/minus more.
The only thing you can do is take it apart, inspect, measure....and measure again once it's put together.
Air leaks and incorrect fuel/not enough fuel are engine killers....period.
so trying to pin point the reason that this happend is probly the gas i was running in it was to low of octane or there was some kind of air leak some were?
well whats you compression again, and timing?. and if it was a carb running dry and it didnt favor a side it would have burnt up both sides.
