petersen302 Posted September 8, 2008 Report Posted September 8, 2008 Hey Guys, I am new to the forums, and have to say, this place is great! I have done som searching, and cannot seem to get the answer I need. After a little run in with the DNR here in Michigan at Tin Cup last weekend, I need Spark Arrestors. Especially because I am going to Silver Lake in 3 weeks! My issue is, I have Toomey T5's with Toomey Silencers. Is there any way to get around buyin the actual Toomey arrestors at are $159 for the set? Thanks in advance! Quote
petersen302 Posted September 8, 2008 Author Report Posted September 8, 2008 http://www.denniskirk.com/jsp/product_cata...tId=&mmyId= Found the above on Dennis Kirk. Does anyone know which size would be needed? I am at work so I cannot messure, and need to order ASAP!! Quote
shanYE west Posted September 8, 2008 Report Posted September 8, 2008 Toomey's are 2.5" The toomey spark arrestors may cost more.. but they fit ALOT better.. They snap in and replace the end cap rather then clamp down onto the silencer body. Quote
Paddleboy Posted September 8, 2008 Report Posted September 8, 2008 you can get the hush kit, then you will only need one spark arrestor. but the hush kit is just as much as toomey sparkys Quote
bansheejoel Posted September 10, 2008 Report Posted September 10, 2008 (edited) you can get the hush kit, then you will only need one spark arrestor. but the hush kit is just as much as toomey sparkys or you can do what we did to your silencers and put some chicken wire in the silencers so when the dnr checks them they think there is a spark arrester...hahaha Edited September 10, 2008 by bansheejoel Quote
jbooker82 Posted September 10, 2008 Report Posted September 10, 2008 or you can do what we did to your silencers and put some chicken wire in the silencers so when the dnr checks them they think there is a spark arrester...hahaha I would imagine that would kill the air flow. Like clamping a pice of fabric over the carbs instead of using a K&N filter. More Surface Area = Better Flow. Quote
bansheejoel Posted September 10, 2008 Report Posted September 10, 2008 I would imagine that would kill the air flow. Like clamping a pice of fabric over the carbs instead of using a K&N filter. More Surface Area = Better Flow. its not like putting fabric over the carbs at all, for how much we used there is no way that it would affect the performance...the stuff that makes a silencer spark arrested is like a screen anywase, that stuff is way more restrictive than what we used lol.. And it was better than spending the $190 on spark arrestors for the 1 time his shee has been to the dunes. Quote
shanYE west Posted September 10, 2008 Report Posted September 10, 2008 Every time one of my buddies tries that they get turned away.. They can tell if its a USFS approved screen or not.. If it dont say USFS approved spark arrestor on the silencer body.. or they cant see the screen.. your not getting in.. But.. it all depends on how anal they want to be. but.. the last 4-5 times my buddies have tried.. they didn't make it through the gate. Quote
petersen302 Posted September 10, 2008 Author Report Posted September 10, 2008 Every time one of my buddies tries that they get turned away.. They can tell if its a USFS approved screen or not.. If it dont say USFS approved spark arrestor on the silencer body.. or they cant see the screen.. your not getting in.. But.. it all depends on how anal they want to be. but.. the last 4-5 times my buddies have tried.. they didn't make it through the gate. I think I am just going with the Toomey Sparkys. I ride Tin Cup alot too, and the DNR there are pretty hardcore. Quote
Dark Ranger Posted September 10, 2008 Report Posted September 10, 2008 My suggestion is to get the Toomey Hush Kit with the built in spark arrestor. That is what I did. I like it and it was easy to install. I have never had a problem with it. It is USFS approved and it has the USFS seal stamped on it. No muss, no fuss! Quote
petersen302 Posted September 11, 2008 Author Report Posted September 11, 2008 My suggestion is to get the Toomey Hush Kit with the built in spark arrestor. That is what I did. I like it and it was easy to install. I have never had a problem with it. It is USFS approved and it has the USFS seal stamped on it. No muss, no fuss! Ordered the Toomey Sparkys last night. Not too excited about spending that much, but it sounded like the best idea. The hush kit would have been just as much . Quote
IrideA250R Posted September 11, 2008 Report Posted September 11, 2008 you'll be glad you bought the Toomey setup. I bought them earlier this year and they fit much better and are 0 hassle compared to the old clamp on ones that scrape the hell out of your silencers. here is a shot of my Banshee with them installed: http://www.silverlakesandduners.com/pics/a...eehaulerswp.jpg Quote
Dark Ranger Posted September 11, 2008 Report Posted September 11, 2008 Those don't look bad at all. I bought the hush kit since the area I was going to ride in had noise restictions and required a spark arrestor. Quote
petersen302 Posted September 11, 2008 Author Report Posted September 11, 2008 Those don't look bad at all. I bought the hush kit since the area I was going to ride in had noise restictions and required a spark arrestor. They have noise laws here too.... But most of the places are pretty flexible. Quote
