wrxguy97
Everything posted by wrxguy97
  1. when diagnosing my problem i noticed that one of the connectors on the old cdi had melted. not sure if thats what caused my orignial problem?
  2. ive had my push rod weld its self to the ball bearing. clutch was always stuck
  3. uned a DVOM to check all new parts, all new parts checked out okay. couldnt check the CDI
  4. hey everyone, Im new to this site and i was wondering is somebody out there has some usefull info for me. last year i bought a banshee from a friend that had major gear box problems for very cheap. The motor ran strong tho... started first or second kick every time. Instead of ripping the engine apart and fixing the bad gears in the trans, i decided to buy an engine off of a reputable seller on ebay. as soon as i got it, i slapped it right in. went to start it, and she didnt want to go. hit it with some starter fluid and it started but ran really rough and wouldnt hold an idle. after a little bit it died and wouldnt start again. took the plugs out and no spark. i replaced the stator, wiring harness (OEM one was hacked to peices), flywheel, woodruff key, kill switch cluster, BR8ES plugs, ignition coil, key delete (twisted the white and red wires), One of the connectors that was coming out of the CDI had been melted (housed the orange ignition wire) i was able to check all of my new parts except the CDI. i bought a cheap $60 one off ebay (probaly not the right choice). Not sure if they sold me a junk CDI or im missing something here. oh and TORS had been deleted since i got it. deleted off carbs and no black box on the frame. i believe the voltage regulator had nothing to do with ignition so i left that alone. If anyone can provide me with any info that would be great! -wrxguy97
