nmrichardson
    JHB, South Africa
Recent Profile Visitors
508 profile views
nmrichardson's Achievements
  1. I have already bought a Electrix World racing ignition system for the banshee motor , it does not allow for PV so I think I'll look for non-PV barrels , however I do agree that the PV would have helped a lot with mid range
  2. yeah , that does suck! try this one http://cubeupload.com/im/nmrichardson/IMG8758.jpg
  3. looks like this at the moment :
  4. cheers guys, wouldn't that be ironic , putting a PV banshee motor back into a RZ rolling chassis, how are those PV's controlled on a banshee motor? I have a 31k RZ350 and the PV's are controlled from the CDI on RPM, but on the banshee CDI there in no output for a PV servo motor ?
  5. Definitely broad power range the motor is going into a RZ350 track bike so don't want it too peaky otherwise the front wheel won't stay down lol
  6. Hi All, Any recommendations for a pre-ported, and plated off the shelf cylinder kit for a 421cc set up? I already have the 4mil crank, so wondering which cylinders work best off the shelf...
  7. I'm busy with a very similar motor spec , but mines going into a 2 wheeler track bike The software we used to port and build the pipes said I should run 34mm carbs But as PWKs don't come in a 34mm I have opted for 33's which should give a bit more mid range power Sent from my iPhone using Tapatalk
  8. Cheers Zilla Sent from my iPhone using Tapatalk
  9. Thanks but blaster Piston does not have offset wrist pin for +5mm rod ? Or are the jugs designed to accommodate the Long rod ? Sent from my iPhone using Tapatalk
  10. Hi guys So my current setup is a long rod crank and 795 Pistons, Since the 795 only go up to 2mm oversize I'm just curious how one would overcome the long rod +5mm over 66mm bore ? Or is 66mm the max bore on Std barrels , and anything higher specially designed barrels ? Sent from my iPhone using Tapatalk
  11. what compression ratio were you running?
  12. I ordered the PWKs but something fishy is up if they not available in 36mm Will have to see the suppliers response tomorrow Sent from my iPhone using Tapatalk
  13. Well spotted !! I've just contacted the guy I ordered the carbs from and asked the question I see there are some "keihin" 34mm PWKs on eBay I hope he is not selling those Thanks for the heads up! Sent from my iPhone using Tapatalk
  14. All of the above , plus kill switch , TORS or CDI Sent from my iPhone using Tapatalk
  15. Haha [emoji23] Dig away bud.... I've ordered a set of 34mm PWK's I'll see how I get on with them Thanks Sent from my iPhone using Tapatalk
