pattheriault
    2005 banshee
pattheriault's Achievements
  1. Can you Pm me a couple reputable shop?
  2. was running 24cc dome on a 4mil with 795 pistons. 91 octane at 32:1 not sure what compression this setup adds up to
  3. Yeah I'm leaning toward Jeff at fast right now. he's the one who originally built my engine and I had great service. i might send him my crank and let him judge if im better off with a new one or not.
  4. every thing else looks to be in great shape.. then again Im no crank expert either.. But you are right being canadian by the time I ship a crank out (probably to the US) to get fixed and then back to me It might just cost as much as a new crank unless someone know of a reputable shop in Canada
  5. Ok so My crank was trued and welded on my last rebuild. 4 mil hot rod crank. My piston melted down and while doing the top end I decided to inspect the bottom end. Glad I did. The bearing on the stator side was shot and the weld on my crank has cracked and it splitted out about 2mm. Can this crank be trued and re-welded or would i be better off getting a new Crank?
  6. Hi guys, I have a 4mil stock cylinder (Dune ported by F.A.S.T) 65mm bore advance timing shearer pipe open airbox with K&N Sea level Just about to complete my rebuild and im wondering what would be a great starting point as far as jetting? 360 and 30?
  7. Thanks! worked like a charm
  8. is there a trick to take the screws out to take out the little plate behind the clutch (Bearing stopper plate)?? they are in there pretty tight and im afraid to strip them in..
  9. Ill try to clean the jug tomorrow but they have a bit of material from the piston on them. I think ill have to bore to 65mm
  10. 4mil, fast dune port, shearer, pod filter,.20 over,24cc dome,+4 degree, vforce 4, 360 main 30 pilot
  11. No i did not.. I suspect an air leak as my carb were cleaned when i did my rebuild but ill inspect them tomorrow
  12. yeah kind of what I figured... will need to find out why.. Would you guys go ahead and split the case to inspect for metal shaving in a situation like this? crank seems tight and in good shape.
  13. What can cause this piston to be as bad and the other one to be in perfect shape? id say around 300km on the 4mil rebuilt Could a bad spark cause this? on my last ride the terminal nut came loose on the plug and it ran on 1 cyl for a short period of time.
  14. On a side note what rear tire are those? how do you like them?
  15. Im not bashing your setup but if you were to cut hole and place some outerwear filter on top of the hole you would basically achieve the exact same performance and security of your setup and it would look a lot cleaner. I understand going with something like you did if your running larger carbs but if your not it seem like a bit of trouble for no real gain over a modded stock box.
