maggdog
Everything posted by maggdog
  1. Damn. Well if you have this on trash is cuz not are in the best shape. But anyways. I think mine are more bad than this one. Shipped? Sent from my SM-A500Y using Tapatalk
  2. Nac's seat cover Sent from my SM-A500Y using Tapatalk
  3. How much? Sent from my SM-A500Y using Tapatalk
  4. maggdog
    Upper case
    Right I understooth, so i'll try get a pair some day Sent from my SM-A500Y using Tapatalk
  5. maggdog
    Upper case
    Don't matter if chain whack Just need don't leak at all Sent from my SM-A500Y using Tapatalk
  6. I removed the lid of the airbox, i try to find the proper jetting adjust and i got just i need airscrew This is the setup: Fmf exhaust Shaved .030 head Vforce 4 Timing to +3 Cyl's Bored to .020 Mains are now 300 Pilots 27.5 Screw 1.5 turns out At sea level Sent from my SM-A500Y using Tapatalk
  7. Need some advice with a shocks setup according to riding style The point is compression and rebound adjustment Example: soft or fast rebound is good for??? stiff or slow rebound is good for??.. mx, trails, dunes... Soft compression appropriate for? Hard compression appropriate for? Sent from my SM-A500Y using Tapatalk
  8. So it's time for get one [emoji57] Sent from my SM-A500Y using Tapatalk
  9. Thanks alot Sent from my SM-A500Y using Tapatalk
  10. Guys what is the most riding style application of steering stabilizer Sent from my SM-A500Y using Tapatalk
  11. Rider weight is 120 pounds Sent from my SM-A500Y using Tapatalk
  12. I don't know about shock setups for stock a arms either +2 +1 arms So somebody that can help with some link for buy shocks for my banshee Has +2 +1 a-arms and i ride trails and street Sent from my SM-A500Y using Tapatalk
  13. Ok, i think I figure out the problem keep the main and all that but only change needle position the 4th to middle pos and run great now, thanks for ideas guys Sent from my SM-A500Y using Tapatalk
  14. Thus looks like old plugs Sent from my SM-A500Y using Tapatalk
  15. Sure I know how do Yes not dents on pipes filter clear Sent from my SM-A500Y using Tapatalk
  16. Well, since i bought the banshee comes with this issue First was that i try to run WOT and the banshee turn off. and now this problem Carbs cleaned and a lot new plugs and still with the problem I'll try to change the jet size Sent from my SM-A500Y using Tapatalk
  17. I'll try to change this jetting and check the electrical system Thanks alot Sent from my SM-A500Y using Tapatalk
  18. Not. but i'll do Yes pick up gap is okay What jetting and notch do you recommend? Sent from my SM-A500Y using Tapatalk
  19. My banshee do similar like this but in high revs and the tors and parking brake and is disconnected https://youtu.be/INQF4uY-Q2w Sent from my SM-A500Y using Tapatalk
  20. I ever had this problem with this quad With all number of jets, 200, 245, 280, 300 and the same mods that i've post before Sent from my SM-A500Y using Tapatalk
  21. Yes the slides are in correct position, half moon in the airbox direction Yes is a good gas because other buddies don't have trouble with the same gas I have not cleane the plugs, ¿how to do? And what plugs? Spark plugs? Harness plugs? Mix ratio? I use 32:1 ratio Sent from my SM-A500Y using Tapatalk
  22. 4th clip from flat end Sent from my SM-A500Y using Tapatalk
  23. 1.5 turns out is the airscrew Sent from my SM-A500Y using Tapatalk
  24. Stock airbox with lid Sent from my SM-A500Y using Tapatalk
  25. Fmf pipes and silencers Intakes? So i suppose is stock boots with crossover tube. not cyl port Sent from my SM-A500Y using Tapatalk
