Craig B
Everything posted by Craig B
  1. I worked it out. There are small nubs on the front hubs [4] that need to be ground away for the wheel to sit flush.
  2. I have a set of Hiper front wheels for a YZF 450. Is there a front hub I can use that will work on my Banshee? Not sure if it's hitting the caliper on not. Thanks for any help.
  3. Looks like I will need a 421 then .
  4. Stock crank. if I'm going to throw a crank in it it will be a plus 4 welded n trued
  5. I am @ sea level
  6. Shit!! I hope I got the right domes in there. compression was 120 with the stock head so it jumped up 60 psi
  7. I was thinking pipes alone where worth 6 to 8 hp.
  8. Isn't stock 37 to 39 if I recall ?
  9. Wise Guy
  10. I was thinking around 50 myself. What do you think it would make as a +4 mil and some porting on stock jugs?
  11. Does anyone have an idea on how much power I could make with my current combo. It's stock bore & stroke with 180 Psi comp. 19cc domes on C12, V force 4 reeds +4 timing stock carbs with K&n pods.SLP pipes. Thanks
  12. I never ran AV fuel , but it is designed for high altitudes. So your best bet may be to try a 50/50 mix with some premium.
  13. Craig B
    Swingarm ?
    Lol!! Who then? Wanted a + 4 in silver vein with round house carrier for around 500 or less. Thanks
  14. Craig B
    Swingarm ?
    Anyone buy from the swingarm shop on Ebay? He has extended swingarms in mild steel for $250. Looking to get a + 4 and would prefer a moly one. Any info were to buy ? Thanks
  15. I think your close. When I talked to SLP they said 290 main also. Thanks for the info.
  16. No porting as of now. Not sure if I will just port or port and big bore. I guess I will see how this current combo runs and take it from there.
  17. Anyone have a good starting point on jetting for my combo? Stock bore & stroke SLP pipes stock carbs with K&N pod filters cool head w/ 19 cc domes [race gas] + 4 timing plate V-force 4 reeds Sea level @ Temp 30 to 50 degrees Thanks.
  18. Just bought this one w/ 19cc domes http://www.farmandsandtoys.com/partdetail.asp?partid=183
  19. Thanks. I just bought a adjustable timing plate too.
  20. Anyone know if 19cc dome is ok with C12 ?
  21. Looking to buy a cool head or one of the other brands out there. Who makes the best one? Can I use 19 cc domes for C12 or purple race gas? Stock bore and stroke. Thanks.
  22. Of course Outerwares are a must!!!
