ClaudeMachining
    110
Everything posted by ClaudeMachining
  1. Hummm... Metrology is a science and no, you can't do what ever you want... Envoyé de mon SM-G935W8 en utilisant Tapatalk
  2. I'll get a chariot kit.
  3. I lol'ed a this one!! But i dont think anybody here would run 39mm on oem thumb for 30 straight min in a trail when you ddint ride since almost 10 month. If i would ride everyday like i used to, maybe, but not after 10 month without riding.
  4. Something like this ? https://www.ebay.com/itm/trx450r-thumb-throttle-06-14-FAST-FREE-SHIPPING-/113124006206
  5. I forgot to say i did another dumb thing lol!!! Everything was good until i was WOT. When the mains where suppose to hit, the motor was falling on his face very, very big time, it was weird!! So i unscrew the plug of the bole to check the main and guess what i found??? The main was in the bottom of the plug lol!!!
  6. I never owned a dirtbike. I was born on a snowmow, so i always use a thumb throttle.
  7. Wich one is the best, Honda or Chariot?? Envoyé de mon SM-G935W8 en utilisant Tapatalk
  8. Mains are at 175 now, i think its a little bit rich, but its hot and humidity is high, so i will live them as is. The engine is a monster, i dont have to down shift as much as my 421, i hitted 10500-11000rpm easily, everything looks good. Thumb is fucking killing me. Envoyé de mon SM-G935W8 en utilisant Tapatalk
  9. Will go all white plastic next season, i think it will look better with the tank.
  10. It's worst than my 35mm, i'll do that but i will change the throttle too.
  11. Did the first ride!!! Front suspension is way better, feels very good. Rear shock was little bit stiff, will play with that next ride. Thumb is too stiff with those 39mm. Engine is very strong everywhere, i was lean on the pilot, didn't pushed the engine. Envoyé de mon SM-G935W8 en utilisant Tapatalk
  12. My springs problem is sorted out. Last thing is filters, but I will make it work this week end I guess. Envoyé de mon SM-G935W8 en utilisant Tapatalk
  13. On my last 2 sets of pipes i had weld on bungs. This time i decided to try clamp on bungs. Envoyé de mon SM-G935W8 en utilisant Tapatalk
  14. Yup. Envoyé de mon SM-G935W8 en utilisant Tapatalk
  15. This!! Envoyé de mon SM-G935W8 en utilisant Tapatalk
  16. Found the right one to go on the bottom side. I drilled a second holes in the spring bracket. I ordered two 55mm and two 60mm to be able to mix lengths Envoyé de mon SM-G935W8 en utilisant Tapatalk
  17. My pipes do not have standard hooks location. I have 3 hooks on each pipes. I'm still figuring the right combo to have the right length. Envoyé de mon SM-G935W8 en utilisant Tapatalk
  18. Motor is running good so far, carbs are at 172, 52, DGH middle clip, timing +4, 165lbs compression, 100LL. will do the first ride soon, but 172 is probably too much, pilot seems ok. I need exhaust springs… The hook on the LED pipes are not a the 'standard' position.
  19. Nope, 'cause the engine was not complete, only cases, top end and pipes where at Redline i will do a dyno session here with o2 sensor etc. Cam said about 115-120hp
  20. Ok guys...You'll laugh at me, but I deserve it!! Yesterday night, I was doing the last heat cycle on my engine. Then it seized, I almost got a heart attack. EGT's were only at something like 450F, water temp was 150F, but it fucking seized!! Was not even able to move the engine with the kicker. So it was late, I just removed the head to look at the pistons, everything looked good from the top and from the exhaust, then a call it a day. Today I removed the clutch cover and look what I find!!!! I forgot to tighten the nut and it unscrew and hitted the cover, you can see the mark lol!!!! If the engine would have been loaded, I don't know how that would have finished lol!!! Envoyé de mon SM-G935W8 en utilisant Tapatalk
  21. 4th start. Envoyé de mon SM-G935W8 en utilisant Tapatalk
  22. Dunno, maybe a smaller diameter filter can be fitted too. Envoyé de mon SM-G935W8 en utilisant Tapatalk
