Cascade Innovations
HQ Site Sponsor!-
Everything posted by Cascade Innovations
Cascade Innovations is having a spring sale on select Billet Aluminum 10% - 60% off - See our website for Details http://www.cascadeinnovations.net/ Also enjoy free shipping on orders over $75 We are having a close out sale on Blue, Red, White, Yellow, and Purple Chain sliders --- ONLY $8 each! http://www.cascadeinnovations.net/store/store_view.cfm?store_area_id=3&STORE_DEPT_ID=10
Why and the hell is my quad overheating
Cascade Innovations replied to dalegoldston's topic in Banshee Repairs and Mods
By the description you just gave, I would guess the following in this order - 1. The water pump is not working (stripped gear or water pump head stripped off shaft) 2. The water pump is working, but radiator is blocked or partially blocked 3. Cooling system is without issue, and you have an air leak, dome issue, or detonation issue causing extreme heat Your 210 main should be fine on that set up when everything is correct. Pilot should be 52-55 and DEK Needle on 3rd- 4th clip -
The NTN 305E is the TZ style bearing we use and stock... Our picture on our website is just of an old photo from when we used OEM TZ http://www.cascadeinnovations.net/store/store_View.cfm?STORE_AREA_ID=13&store_dept_id=235 Current bearing in stock
Cascade Innovations Christmas Sale
Cascade Innovations replied to Cascade Innovations's topic in Sponsor Spotlight
We do not carry any head shells for DM's -
Our free gift offer applies to our "Discount Packages" only - http://www.cascadeinnovations.net/store/store_view.cfm?store_area_id=3&store_dept_id=1057 All other standard orders over $100 will receive free shipping -
http://www.cascadeinnovations.net/store/store_View.cfm?STORE_AREA_ID=3&store_dept_id=1057 http://www.cascadeinnovations.net/store/store_View.cfm?STORE_AREA_ID=3&store_dept_id=1057 Take a look at our Cascade Christmas specials listed on our website We Have Performance and Billet packages, as well as free shipping! On top of all our sales, each day we will be offering a different free gift with purchase of one of our discount packages
Cascade trail tech lights
Cascade Innovations replied to Andreb84's topic in Banshee Repairs and Mods
Ticking noise at idle *Video*
Cascade Innovations replied to Rapture's topic in Banshee Repairs and Mods
From the videos you have posted, I believe that you are hearing your aluminum labyrinth seal "clicking" between your two inside crank bearings. The video that confirms this best for me, is where you are rotating the flywheel by hand. This is a common issue we see with factory crankshafts, where there is no o-ring located on the lab seal. Most aftermarket crankshafts have at least one, if not two o-rings installed to prevent the seal from moving side to side. You can confirm this to be your issue by simply unbolting your reeds from the cylinder and rotate the flywheel by hand just like you did before. The crankcase will no longer be sealed and thus, put little to no pressure on the lab seal back and forth. If the clicking is now gone from removing the reeds , the good news is - it really is not hurting anything and a repair is not required immediately. However, to repair the issue, an o-ring should be installed on the lab seal. If you remove the reeds and the clicking persists, I would recommend that you tear down and inspect for a damaged bearing on the crankshaft. Good luck! -Chris -
Transmission counter shaft dissasembly
Cascade Innovations replied to Rage_kage's topic in Banshee Repairs and Mods
Judging by your picture, it looks like the Idler gear shim (goes behind the idler gear) It also looks like the 2nd pinion gear shim, but that is on the main shaft, so if you did take them apart 100% seperately, it would not be that. -
We have spent a bit of time testing SLP pipes on a couple of our cheetah cub motors. The face of the curve on the SLP is all of that of the paul turner mid range, plus 10 HP on top. In real world riding, the SLP's pull incredibly hard through the mid range, but do fall off quick at 8,500 RPM. Paul Turner Mid range pipes are an untouchable pipe for bottom end performance but do limit top end horsepower. The following dyno chart is one of our 421 Cheetah cubs as cast, Race Gas, 2 into 1 Intake (38PWK), comparing Paul Turner Mid Range pipes to SLP. BLUE LINE-PAUL TUNER RED LINE - SLP. Paul Turners begin to develop a very usable and smooth curve as low as 3K RPM, where the SLP struggled to be loaded heavily until 5K RPM. Both lines follow eachother very close in the mid range, and the SLP only begins to outshine Paul Turners at 7,500 RPM. Both pipes do lose HP quick past 8,400 RPM, but the SLP is the worse of the two for over rev.
These overflow tubes are a press fit into the aluminum. No solder here. The bowls are machined to this specific tube. The overflow tube is typically needed for gas bikes to avoid gas overflowing into the motor. It is very common in alcohol carbs with billet bowls to not have this feature. This overflow tube was designed exactly the same as the standard Keihin bowl overflow tube.
Cascade Innovations is now offering billet oversized carburetor bowls to fit 33-41mm Keihin PWK's. -These bowls hold 65% more fuel than the standard keihin bowl - Offset Bowl nut to access main jet and pilot jet with ease - Press fit overflow tube -Hardware & o-rings included We offer these in singles as well for those with 2 into 1 carb set-ups to increase fuel capacity. Singles are $80 in Machined Finish, or $115 in Polished Finish Sets are $160 in Machined Finish, or $220 In Polished Finish Bowls are in stock in both machined and polished and ready to ship. http://www.cascadeinnovations.net/store/store_view.cfm?store_area_id=13&store_dept_id=1019
We are excited to be new Banshee HQ forum sponsors, and wanted to introduce ourselves! We opened in 1989 and are celebrating 25 years of business this year! Our business started with Vinyl products for all makes and models of which we still do today. We have greatly expanded our business since our inception, and have been building high quality performance motors and products for the past 20 years. Through the evolution of the ATV industry, we've taken great pride in the fact that we have stayed the course with servicing and building banshee's only. We have a great selection of motor combinations to meet the needs of your style of riding. If you would like assistance in deciding on a motor package, we will be more than happy to suggest an engine that best fits you via our extensive R&D in both real world and dyno time. We have the largest inventory of Factory and Aftermarket Banshee parts in stock. Some of the items we stock at our shop include; -Full line of Show quality Billet Aluminum accessories -Exclusive Show Chrome Genuine Yamaha Hardware -Extensive line of Genuine Yamaha Banshee Parts -Wide Variety of Engine build components -And so much more To see a full list of items that we carry, visit our website at www.cascadeinnovations.net - or - Come see us at our large showroom located at; 13090 S.E. Orient Drive Boring, OR 97009 503-663-2887 -Tim & Chris @ Cascade Innovations
