89mustang
Everything posted by 89mustang
  1. Nyuk I found one just after I put this on here and ordered it. I wish I would have seen that. I ordered one from Motorsport. It was like 14. See how long it lasts
  2. Took the banshee out for a spin and I noticed a lot of chain noise I checked it out when I got home is the bottom roller supposed to have rubber or poly on it. That was where the noise was coming from. Everyone seems like they just sell the upper roller
  3. Alright thank you ill check that
  4. Got home sprayed carb cleaner all around the reed block gaskets found nothing. I took it for a ride and it was idling fine when I got home
  5. Would carb cleaner work? Like when your looking for a vacuum leak on a car.
  6. there's a thread on here how to make a leak down tester. You think my pilots or jetting would be close for 650' elevation
  7. Yesterday I installed v force v4 reeds. I cut the tabs off the intake boots made sure everything was flush bolted it up. Started it idle seemed normal took it for a quick spin came back and it had a high idle. It might be the jetting I have a 27.5 pilots stock needle in third clip and a 300 main. My question is there a way to check and see if the Reed gasket are leaking?
  8. I've bought a few things from fast. I'm pretty much just going to have a bolt on banshee. Jeff from fast is awesome to deal with. I've already bought a adj. timing plate,v4 reeds, pro flow air filter and now the cool head
  9. Ok thanks everyone. Just wanted to make sure
  10. I'm buying a cool head. I've been doing the research seems like noss is the one to buy. Fast has one designed by noss so I was curious us it the same ?
  11. Thanks. I would love to go earlier, but September is booked up for me. I appreciate the invite though.
  12. I've never been here. My brother and a couple of buddies were going to plan a trip for the beginning of October . Any tips I need to know? Any recommendations on where to stay? Any other helpful info Thanks in advance
  13. My banshee is stock except a set of toomey's
  14. Funny this came up, I was just at the badlands last Sunday and my brother has a crf450 and he walked me pretty good from a roll. From a dead stop I hung with him till 3rd. I just talked to Jeff at FAST and I'll have a surprise in store for him soon.
  15. Thank you for all your replies. I'm more familiar with supercharged mustangs than the banshee's. I know more compression equals running race gas but low compression supercharged /turbo motors can also require it because of igmition timing.The E85 comment was a smartass comment on the nitro methane comment
  16. Thank you for your help.
  17. Oh I was gonna change it so I could run E85
  18. I've searched on here couldn't get a deffinate answer. If I get an adjustable timing plate do I have to run race gas? I live at 650' elevation mods currently are t-5's and a cut air box lid.
  19. Anybody have a set they want to sell?
  20. I have a '09 night train for sale it has 5400 on it. V&H big radius pipes Screaming eagle heavy breather Dyno tuned have the sheets I live in the Chicagoland area I'm looking to get 14,000 obo for it title in hand. I'm interested in the following trades 66-77 bronco, 1993 cobra mustang or 08 or newer hayabusa. Call or text for pics 1-815-955-5508
  21. Ok thanks. I'm new to rejetting a carb never have done it before this weekend. The banshee is all stock you think the middle clip won't be to lean
  22. Drop the needle to richen it or lean it out?
  23. Could it be my pilot is too big. Had kind of a high idle with the stock 25 in.
  24. I've just put on a set of t5's and silencers. Runs awesome. I have a 27.5 pilot in 300main and stock needle on the 4th clip down from the top. It's runs good,but if you just tip in the the throttle it'll die out. I have the air box lid on but a 4x6 hole cut in the top and snorkel removed. 650' elevation. Also pilot screw out 2.5 turns.
