Bennett69
Everything posted by Bennett69
  1. Looking for advice banshee was running fine still is when it warm when I start it up idles fine once I start to ride her she's staying revved up and start to run away abit once she's warm she's perfect any help would be appreciated
  2. What's the best oil to use for mix I was running ipone but can't find it where I live now any suggestion would help
  3. Thanks for the help
  4. No ran perfect I recently moved across Canada so elevation changed from 5000 to sea level
  5. I was thinking pilots too small but wanted second opinion before pulling carbs apart again thank
  6. Pt mid range cfm intake tors delete
  7. Idles fine when it's warmed up and running I have bog at low rpm goes away in higher rpm any help would be appreciated
  8. are your carbs syc'd properly
  9. Do you ship to canada?
  10. cool man mainly looking for the kick side but will take both if you have em lemme know
  11. Bennett69
    splash guards
    looking for the black plastic heel/splash guards
  12. Bennett69
    WTB cases
    cool thanks ill pm
  13. thinking about buying a set of fullflight +3 with yfz 450 shocks anybody running this set up or know how it performs
  14. Bennett69
    WTB cases
    looking for a engine cases in good condition
  15. sweet looking shee
  16. how much for heel guards with plastics
  17. all i did was order a kit from ebay itll come with everthing you need
  18. heel guards and cylinders still avaible
  19. perfect thanks for the info and the pics i like the tether cleans up nicely
  20. so will the tether replace the ignition
  21. anybody on here move there ignition if so where did you put it
  22. do you have the plastic splash guards behind the pegs?
  23. forgot to mention got pt midrange pipes
