Tony Doukas Racing
HQ Site Sponsor!
Everything posted by Tony Doukas Racing
  1. We make fiber reeds for the Delta V Force cages in different thicknesses and tensions that are resilent to methanol and have the stiffer requirements. Contact us at 941-505-0800 or [email protected] $65.00 for a set of 8 petals
  2. Never talked to Ducman personally but send a PM to fix the issue. Besides I have 2 Duc's in the garage. I am an avid motorcycle racer as well.
  3. They are done. I just have not had the time to list them . call me or e-mail me at [email protected]
  4. Yes we do. I have several different ones available. Call me at 941-505-0800. As well as all the go fast goodies
  5. Our new website is up and running. Check it out for performance and OEM parts. www.tdrrz.com
  6. Yes give me a call
  7. $800.00 TDR Crank I buy just the webs and they are completely assembled with max load bearings. TZ as an option. Welded and pinned in the center.
  8. Most of my customers do not know this but we have to advertise at a specific minimum retail price or we lose our dealer status. Those that sell for cheaper on EBAY eventually get caught and the price either changes or they are dropped by the supplier.
  9. shows it went but paypal is slow right now.
  10. They are locating pins just like the OEM Yamaha crank. They have to be positioned in the groves at the seam of the cases.
  11. Took this out of a customers atv that has been sitting indoors for years . Serial # 16,270 so it was one of the last cranks that I rebuilt. That is how many crankshafts we rebuilt in the days. Stock outside OEM webs, Hot Rods forged inner webs that are rebuildable, hot rods connecting rods, and NTN bearings. Welded in the center. $ 175.00 shipped.
  12. The ULTIMATE Front Wheel Bearing for Spindle mount wheels. Silicon Carbide Wheel bearings for 5/8 spindle mount wheel will give you the best reduction in rolling resistance. $ 35.00 each. We also stock all the rear axel bearings as well. Call me for pricing. 800-321-6354 or 941-505-0800 Silicone Carbide, Ceramic bearings are the Ultimate in the reduction of rolling resistance caused by standard style wheel bearings. 40% LESS FRICTION over steel bearings. 60% less rotating mass & weight. 3 to 5 times the bearing life with no maintenance required. These bearings have been used for years in all the motorsports areas. Nascar, NHRA Dragsters, Indy Car & Formula 1, SCCA, IHRA, AMA Road Racing. Available in almost any bearing size. Rear axle ceramic bearings are also available.
      • 1
      • Like
  13. These all stainless powerjets flow more than the cheaper brass powerjets. The Thunder PowerJet fits any size or brand carburetor. It is exactly what you need to achieve maximum performance with your engine. The TPJ improves performance by precise fuel metering with needle valve adjustment. Fuel distribution is improved by adding fuel through two sources instead of just one. This means more horsepower at any temperature or altitude. The TPJ gives you a range of over 10 to 12 jet sizes with precision external adjustment. Thunder PowerJet works great on stock or modified motors, two cycle or four cycle engines. TPJ can be used on Turbo, Blower or Nitrous equipped engines. A one way check valve is included which holds fuel close to the TPJ for extra quick throttle response. The one way valve also protects against blow back from the engine to the carburetor. The TPJ can be used with fuel injection by adding a remote float bowl. The TPJ body is nickel plated to resist corrosion and keep it looking sharp. The viton seals are compatible with all fuels including race gas and alcohol. A large knurled knob with an index pointer makes adjustment easy. Each kit comes with complete instructions and necessary mounting hardware. Installation is easy and tech support is available. This is a 2 cylinder kit. Part# TPJ-2 Pictured is a extended floatbowl nut that is not included. I use the overflow fitting and remove the tube inside the float bowl.
  14. NEW !!!! from Tony Doukas Racing. Rear Stainless Steel rear brake rotor for Banshee. $100.00 FREE shipping by USPS Priority in the US. PM me , Call me at 941-505-0800, or go to EBAY : http://www.ebay.com/itm/TDR-Stainless-Steel-Rear-Brake-Rotor-for-Yamaha-Banshee-/271393774779?pt=Motors_ATV_Parts_Accessories&hash=item3f30545cbb&vxp=mtr
  15. We can put ends on them to keep from sliding off. They can also be custom engraved with your shop name or your personal logo.
  16. TDR Billet aluminum drag race foot pegs for Banshee. 13.5oz. $100.00 for the pair.
  17. TDR Fiber Reeds & TDR Carbon Fiber Reeds on EBAY Here is a link to my reeds available on EBAY. 4 styles to choose from. Fiber reeds for stock and slightly modified engines. $30.00 Fiber Reeds for modified engines. $30.00 Carbon Fiber Reeds for stock & slightly modified motors. $40.00 Carbon Fiber Reeds for modified engines. $40.00 All include free shipping by US first class mail. Quicker shipping available thru the EBAY link for additional $. The link is to my EBAY store. http://stores.ebay.com/Tony-Doukas-Racing-and-TDR911?_trksid=p2047675.l2563 Lots of new things coming.!!!!! Custom Reeds are also available for Nitrous & Turbo applications. Contact me at 941-505-0800 [email protected]
  18. Are they the aluminum cages??? Pics would help Go back to the rubber coated cages, modify them and use TDR reeds specifically designed for the application.
  19. You can put me down as well. I have lots of different setups to put one on. From dyno engines to trail bikes. Always looking for new products to test and carry.
  20. The only ones I see that are not included is the swing arm pivot bolt & the upper A-Arm pivot bolt, & foot peg bolts. Lower A-Arm ones are included. Each bag is marked separately. You can also but them thru my website as well. In the Frame section.
