ClayAiken
Everything posted by ClayAiken
  1. Looks good A-Arms are tough to keep looking good.
  2. If you had someone go through it i would check pickup gap on flywheel and maybe the coil i remember someone having the same problem and had a bad coil. If all those are good i would say its the stator.
  3. Its an OEM stator right?
  4. Im pretty sure you can use the key however the plate is better. Pull out that key put in stock set gap and see what it does.
  5. He hasnt signed in since 11/29/11
  6. Remember the flywheel and did you set the gap? Test coil also. Where it was a teardown sounds like a ground to me.
  7. Learn how to post in the correct section. You werent even close.
  8. Rip apart the Carbs and Clean.
  9. They were replaced with 20-11-9 Holeshot HD's from RockyMountian.
  10. Its a Gamble. OR He has no clue what there worth. Look for cracks seperation play ANYTHING you can find wrong if you do find something wrong walk away.
  11. Doesnt sound bad to me. What do your plugs look like? Did you do a plug chop?
  12. Thats what mine sounds like.
  13. Mine moves a little. As long as its not too much run it.
  14. Ive never heard of them. Hot Rods or Wiseco thats it.
  15. Yes your going to have to jet. You will be running leaner with pods.
  16. Bull....Shit.
  17. Im sure someone has done it. Remember one piece is stronger then a weld.In most cases.
  18. Noss Heads use orings i believe. No you cannot use 38 lectrons on stock motor. Sell them and buy some stockers or 28 pwk's
  19. Hahahaha you gottem good with the Doors Zilla.
  20. The Overflow tubes?
  21. Woah those pipes look mad weird.
  22. A Big bumper and a Bar Pad.
  23. Might want some +2+1 Arms and a +2+2 axle then
