escobar
Everything posted by escobar
  1. escobar
    WTB: Pipes
    sheerider hooked it up. thanks.
  2. escobar
    WTB: Pipes
    can you post them on here or to [email protected]. do you have paypal?
  3. escobar
    WTB: Pipes
    pics?
  4. escobar
    WTB: Pipes
    I need a complete exhaust system for the 98 shee. Anyone got one? I like the toomey or pro circuit. thanks
  5. 1) What type of aftermarket exhaust do you have? stock 2) What type of airfilter do you have? K & N 3) Are you running? stock airbox with NO lid 4) What is your elevation? 900 5) What size pilot jets are you using? 25 6) What size main jets are you using? 220 7) What temperature is your Banshee jetted for? 40f 8) Do you have a port job? no 9) What kind of carbs? stock Mikuni 10) What size carbs? 26vm roundslides 11) Do you have a coolhead? nope 12) What brand is your coolhead? NA 13) What size domes are you using? NA 14) What type of fuel are you using) 87 pump 15) What gas/oil ratio you use? 40:1 16) What type of premix you use? yamalube
  6. you can try checking out a few of these as a reference: http://bansheehq.com/forums/index.php?showtopic=99361
  7. escobar
    Carb cap holder
    I need the little piece of metal that mounts to the side of the carb and holds the cap from coming off. The left side one. thanks. pm me if you got one.
  8. awesome. Mine is stock so it should be good. Gonna try it out today and see if it is improved.
  9. good thinking, I forgot about different carbs...gonna try a few bigger and then post my results.
  10. yeah I went through a bunch of them and some of them confused me more haha. One guy had 170 main and others had like 300 haha. Im gonna get a few sizes bigger and see how it works. It is getting cold here too, 40-50 is the high.
  11. I have a 98 shee all stock except airbox lid removed and k & n filter. It runs great with the stock 200 and 25 jets but it cuts out a little bit on the top end when close to wot. I was wondering if I shoud go up to a 210 or down to a 190 or so? Im going to do a plug chop tomorrow and post pics to see what you all think. thanks in advance.
  12. the grooves are not too deep, I filed them smooth pretty easily. I will try it out, if it doesnt help I will just replace it.
  13. yea, they dont feel good. I think that is what my problem is. The discs cant slide on that surface easily. As long as I can file them smooth thats the route I will go.
  14. Are these grooves bad? Can I file them smooth? The discs and springs are all in spec..
  15. cool deal, thanks.
  16. thanks, I have a digital caliper so I should be good. I adjusted the cable so it points at that mark and I have NO clutch haha. I cant get it to move...I have to screw the cable in to get it in gear...
  17. thanks guys, gonna pull it off tomorrow and see whats going on. Do I need any special tools to do it?
  18. thanks, i hope they do haha. I wonder if those friction and seperator plates just wear out or what? I cant feather the cluch at all, it just all or nothing..not fun to ride from a stand still.
  19. I need to check those things. I do believe that my clutch lever is all the way out. I will check the mark and see if it ligns up as well. I was mainly wondering what wears out and needs to be replaced usually, guess its hard to tell until you disassemble the clutch...
  20. thanks, it wasnt too bad. Now I have to figure out what to get for the clutch...haha
  21. Whenever I let the clutch out it has no engagement until the very end, when the lever is almost totally out. Is this something I can fix with adjustment or does it need a new clutch? I found this on ebay, is this what I would need? http://www.ebay.com/itm/Clutch-Kit-Heavy-Duty-Springs-87-06-YAMAHA-BANSHEE-350-/160663630984?pt=Motors_ATV_Parts_Accessories&vxp=mtr&hash=item25684c7488 thanks!
  22. I figured it out, it was the pilot jet. It was wayyy to big. Thanks for all your help!
  23. Also, my airbox has a few broken clips, I think im just going to run it without it. How much do you think that will effect the jet size? thanks
